drill bit sharpener
/ drill bit sharpener #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
anyone use them.. either jig style or the self contained motor units.
I have accumulated a box of old hss bits over the years that are too dull to use.. though might be saved and at least use them on wood or cast iron ??
soundguy
/ drill bit sharpener #2
i have the drill doctor 750x unit...and i swear by it.
been using it for several years. its easy to use and can sharpen from 3/32 to 3/4" with ease. i paid about $100 on craigslist for the thing
/ drill bit sharpener #6
drill doctor
<aol> ME TO! </aol>
Have one of the very first drill doctors, and its saved me its cost 2-3x over, by being able to quickly and easily resharpen larger bits.
Takes a few times to get the hang of it, but once you do its nearly idiot proof.
I've been shown how to resharpen on a grinding wheel but never could get the hang of it, and had a hard time keeping the angles between the two side of the bits uniform. The DD holds the bit in a jig and makes it just about impossible to get two different angles.
/ drill bit sharpener #8
One more vote for the Drill Dr.
I always turn bits into garbage with the jig and grinder. Drill Dr. is fast.
/ drill bit sharpener #9
Drill Dr! I am not a fan of 'as shown on tv' stuff but the drill Dr is very good!
/ drill bit sharpener #10
If you are real serious about a drill sharpener you might check out Darex. They are professional units. They are qlty and spendy.
I have an older model M and it was about $800 more than a decade ago. Today's low end model is selling for about $1500.
There are a couple of these older models on ebay and asking price is $400.
They are not for everyone but are hard to top for the serious user.
are the grinding wheels in the drill dr replaceable?
thanks
soundguy
/ drill bit sharpener #12
One of the big benefits of having a drill sharpener is the freebee old bits that guys give you cuz they're too lazy to sharpen their own.....
I also vote for the Drill Doctor..:thumbsup:
sounds like a dd might be on my xmas list :)
soundguy
/ drill bit sharpener #16
Let me preface this comment by saying I'm cheap......
Now, way back a long time ago, I had a friend who happens to be a VERY good machinist to teach me the proper way to sharpen drill bits with a bench grinder. It takes all of about 30 seconds to make the worst broken bit cut like a new one. So...If someone GAVE me a "drill dr", I MIGHT use it. Otherwise, it's "old school" for me until my days are done.
/ drill bit sharpener #17
I do this with larger bits but the eyes ain't what they used to be. Soooo.....another vote for the drill dr. got one, love it.
/ drill bit sharpener #18
I too felt pretty good about hand holding bits and getting a pretty good sharpening. Sometimes had to repeat the process to get a bit to bite and spill out good shavings. (I'd often find myself in someones shop needing a drill bit to find all of them with corners broken off or so dull they couldn't be pushed through thin steel even with a drill press. A quick pass or two or four on a grinding wheel brought them back to useable bits).
Also had a jig that was set up on a good grinding wheel. Hand sharpening was quicker and better angles.
Then I bought the Drill Dr. Hands down, as others here have learned, better sharpen on bits. Under 3/16" I just buy new. Have a new wheel but have yet to use it.
Now I have sharp drill bits in every corner of the house, shop, garage and property. :drink:
/ drill bit sharpener #19
I use to be a bend grinder type sharpener but I broke down and got the 750x and now only use the bench grinder to reshape broken bits and to do the ones larger than 3/4". I will say this, if you've overheated the bit it'll never hold a sharp edge, kind of like a chain saw chain. Also I haven't had great luck sharpening small bits but those are the ones that I always seam to have an endless supply of.
/ drill bit sharpener #20
Same here, when I was about 12yrs old a helping a farmer/machinest he had me sharpen a 5 gal buck full of bits and wouldnt pay unless they worked good and I had to try every one on a test hole after 3rd or 4th day;) I got real good at it. Ever since It takes me about 15 or 20 seconds to get them right on the bench grinder if it has a good wheel on it.
Its one of those things if you get the hang of it its easy if not the drill dr is the way to go.
66'' SKID STEER BUCKET (A61572)
66'' SKID STEER...
1068 (A63291)
1068 (A63291)
429858 (A61165)
429858 (A61165)
2017 John Deere R4030 (A64119)
2017 John Deere...
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
