Draining air compressor
/ Draining air compressor #11
I will take some pictures this weekend. I had posted before, but can not find the thread /forums/images/graemlins/shocked.gif
/ Draining air compressor #12
Junk actually I figured that you would ask me for the second picture so I took it last night when I shot the other picture. There isn't a whole lot to see other than the T where the switch connects to my pressure switch unloader. I am sure there is more than one way to install the automatic purge valve but I always shoot for the easiest way! /forums/images/graemlins/grin.gif /forums/images/graemlins/laugh.gif
Hope this all helps you a bit. I don't think you can go wrong for the price of the auto purge valve.
/ Draining air compressor #13
Junkman, take a look at this link. It explains everything you ever wanted to know about the HF automatic drain. I have one on my 60 gal compressor. Works like a charm.
Auto Drain Instructions
/ Draining air compressor #14
MadReferee nice job with the valve instructions.
Junk even you should be able to follow those pictures to get one installed on your tank. /forums/images/graemlins/wink.gif /forums/images/graemlins/crazy.gif
You should write instructions for a living, those are the best I've ever seen. I'm so tired of reading things like "Problems all be happy if read instructions" and having illustrations that look like the wanted posters at the post office. You'd think companies can't afford to buy a digital camera.
I ordered my drain valve yesterday. I think I'll run a plastic tube out the wall because it's really humid in the summer and I don't want to take a chance creating an ice slick in the winter.
/ Draining air compressor #16
</font><font color="blue" class="small">( Junk even you should be able to follow those pictures to get one installed on your tank. /forums/images/graemlins/wink.gif /forums/images/graemlins/crazy.gif )</font>
You are getting closer to receiving the horse head with every post. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif Maybe I should send a Boars head instead.... that way, your wife will think it is your twin.... /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif
/ Draining air compressor #17
Here is a picture of my Quincy QT25 compressor. As you will note, there are a couple of copper lines. The copper line with the twist valve in it, causes the compressor motor to run continuously without shutting off when you turn it. When the compressor brings the tank to the shut off point, the compressor disengages but continues to spin the flywheel. This is for faster recovery. It is a feature that I rarely use. Which line would I cut? Do you have any idea, because I don't.... thanks Junk....
/ Draining air compressor #18
another view......
/ Draining air compressor #19
one more........
/ Draining air compressor #20
Gentlemen (and I use that word very loosely),
I cannot take credit for that write-up. I got the link from someone on the PracticalMachinist forum.
Junkman, one of those copper tubes must be the unloader but I have no idea which one. My compressor is similar to the one in the write-up so I had no problem figuring mine out. If you have a parts diagram of your compressor you might have more luck finding the unloader line. On mine, if the unloader line is broken the compressor will always run.
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2014 Aerway Aerator (A55973)
2014 Aerway...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2011 INTERNATIONAL 4400 (A60736)
2011 INTERNATIONAL...
