Drag I Built
/ Drag I Built
djradz said:
1*I built one similar once to prepare for some grass seeding. Only difference was I made it twice as wide as it was taking forever at only 3' a pass.
2*Also, I nailed a row of concrete nails (regular just bent over) into the bottom to help scarify the surface just enough to provide a little loose soil for the seed to take better.
1*I built mine for narrow strips say up to 16 feet wide so I didn't want it very wide.
2*I didn't need nails or anything like that on mine as the soil had already been loosened up with the tiller.
I just needed the drag to smoth out and level up the already loose soil.
I have an old spike tooth harrow about 4 or 5 feet wide that I want to rig up to a 3 pont boom pole someday so I can lift it to carry it and turn it around at the end of making a pass with it.
/ Drag I Built #22
Nice work on the wooden implements.
LBrown59 said:
it's gettin outa hand an goin off the deep end.
I think the not so subtle hint is you need a welder!
2006 FREIGHTLINER CST120 STAND UP SLEEPER (A67714)
2006 FREIGHTLINER...
2019 INTERNATIONAL HX615 SBA 6X4 DUMP TRUCK (A65057)
2019 INTERNATIONAL...
TORO SGR-13 STUMP GRINDER (A67714)
TORO SGR-13 STUMP...
AIR GREASE PUMP W/STAND AND GENERATOR (A67714)
AIR GREASE PUMP...
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
2020 JOHN DEERE 325G SKID STEER (A65056)
2020 JOHN DEERE...
