DR Brush mower deck
/ DR Brush mower deck #1
Mike058
Key Peninsula, Wa
Kioti CK3510SE
I haven't gotten a chance to take it out for a spin yet. But in trying to move from one part of the shed to another, I stepped on the deck in order to get over the machine (no room to go around). I weigh 180 and the deck didn't flex a smidge. Solid like a tank.
I have the thicker blade for it and was wondering if a 1/2" breaker bar will be enough to remove the nut.
/ DR Brush mower deck #2
Mike;
A 1/2" breaker bar will be enough to remove the blade. I'm curious to hear from you if your "heavy" blade is that much different from the "regular" blade. I didn't see much difference between the two when I installed mine.
SimS
/ DR Brush mower deck #3
I haven't put the thicker blade on yet, there is still room on the original for many more sharpening. The heavy duty one is thicker.
Not sure what a breaker bar is?
But it is quite an ordeal to loosen the nut to get the blade off, I sharpened it after one year, pretty beefy.
Breaker bars are great. Long steel handle with a fitting on the end for a socket. Makes any guy Superman. I use a 3/4" bar to loosen and tighten the trailer balls onto the ball mount. The 1/2" one gets lug nuts on and off the truck or van.
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
2022 CATERPILLAR 259D3 SKID STEER (A64279)
2022 CATERPILLAR...
2016 John Deer 5075E (A60462)
2016 John Deer...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
