DR Brush mower deck
/ DR Brush mower deck #1
Mike058
Gold Member
Key Peninsula, Wa
Kioti CK3510SE
I haven't gotten a chance to take it out for a spin yet. But in trying to move from one part of the shed to another, I stepped on the deck in order to get over the machine (no room to go around). I weigh 180 and the deck didn't flex a smidge. Solid like a tank.
I have the thicker blade for it and was wondering if a 1/2" breaker bar will be enough to remove the nut.
/ DR Brush mower deck #2
Mike;
A 1/2" breaker bar will be enough to remove the blade. I'm curious to hear from you if your "heavy" blade is that much different from the "regular" blade. I didn't see much difference between the two when I installed mine.
SimS
/ DR Brush mower deck #3
I haven't put the thicker blade on yet, there is still room on the original for many more sharpening. The heavy duty one is thicker.
Not sure what a breaker bar is?
But it is quite an ordeal to loosen the nut to get the blade off, I sharpened it after one year, pretty beefy.
Breaker bars are great. Long steel handle with a fitting on the end for a socket. Makes any guy Superman. I use a 3/4" bar to loosen and tighten the trailer balls onto the ball mount. The 1/2" one gets lug nuts on and off the truck or van.
2014 Lincoln MKX SUV (A59231)
2014 Lincoln MKX...
KUBOTA M6S-111 TRACTOR (A59823)
KUBOTA M6S-111...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
2013 Ford Focus Sedan (A59231)
2013 Ford Focus...
2011 Nissan Rogue SUV (A59231)
2011 Nissan Rogue...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
