Double "http://" corrupts urls
/ Double "http://" corrupts urls #1
Rch
Platinum Member
Central Wisconsin
1986 Ford 1910 with 770B (FORD) loader, 4 MFWD; 1986 Bolens G214,back hoe,loader,MFWD (Iseki) 21 hp)
Double "[url]http://"[/url] corrupts urls
Muhammad, when a URL is cut & pasted into a message, then the " bracket url bracket" LINK bracket/url bracket" manuever done to make a link, you end up with 2 "http://'s" in the URL that renders the link inoperative. Is that just the way it is? On my Internet Explorer a missing "http://" is automatically added. I think most dysfunctional links are caused by this.
RCH
/ Double "http://" corrupts urls #2
Re: Double "[url]http://"[/url] corrupts urls
If you enter the URL properly, it will work properly. The only case that I have found an extra httlp:// to be added is if the URL is an https URL. If you enter www.tractorbynet.com between url tags you get http://www.tractorbynet.com... since it adds the http:// to the front. If you enter http://www.tractorbynet.com between URL tags, then you get http://www.tractorbynet.com...
/ Double "http://" corrupts urls #3
Perhaps RCH is talking about a copy and paste error I have made more than once. /w3tcompact/icons/blush.gif
If you're using the tag and accidentally copy in a leading space, like so:
[url= [url]http://www.tractorbynet.com]
... (note the space after the equals sign), you will get an extra "http://" inserted in front of your intended URL.
Stripping leading spaces is pretty heavy-duty software /w3tcompact/icons/wink.gif, but I'll bet we could lobby to have it added to the next generation of improvements.
/ Double "http://" corrupts urls #4
Re: Double \"http://\" corrupts urls
dmccarty's message in the Tractor Safety forum this morning is an example of what happens. The link doesn't work as it is.
Bird
/ Double "http://" corrupts urls #5
Yeah, he had spaces at the front and back... you just have to get the URL without spaces within the brackets.
/ Double "http://" corrupts urls #6
The formatting example in the help file does show with leading and trailing spaces, though...
BobT.
A Indiana Boy
2024 John Deere RS72 Skid Steer Cutter (A65640)
2024 John Deere...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
Landhonor Quick Attach Tree Puller (A66285)
Landhonor Quick...
Case IH 200 50' Field Cultivator (A66285)
Case IH 200 50'...
Rear Axle For Case IH 2388 Combine (A65640)
Rear Axle For Case...
2022 EZ-GO ELITE...
