Door opener problem
/ Door opener problem #61
New unit will fix the issue. 👆
/ Door opener problem #62
I have a Chamberlain garage door opener, about 15 years old. The problem is getting it to go down with a remote. I have one remote and one car both programmed for it.
It always goes up and down with the button in the garage. It always goes up with the remotes. It will sometimes go down with either the remote or the car but it’s less than 50% of the time. If I try and lower it with a remote and it doesn’t work it will go down with the button in the garage so I do think it’s the safety eyes.
Getting closer with the remote doesn’t help. I reprogrammed the remote and car, that helped for a day. I also read a CFL or LED can interfere with the signal. I have a regular rough service light bulb in it and taking it out doesn’t help.
Any thoughts? dövüş oyunları apk indir
It sounds like an issue with the safety sensors, which can sometimes be misaligned or dirty, causing intermittent operation. Try cleaning the sensor lenses and ensuring they’re properly aligned. Also, check for any obstructions in the sensor’s line of sight. If the problem persists, the sensors may need replacing.
No that’s not the problem. The problem was diagnosed and the opener replaced.
/ Door opener problem #64
It seems the problem might be with the safety sensors — they could be dirty or out of alignment, leading to inconsistent performance. Try wiping the sensor lenses clean and making sure they’re correctly aligned. Also, look for any objects blocking their line of sight. If the issue continues, you may need to replace the sensors.(y)
/ Door opener problem #65
No, that wasn’t the issue. The real problem was identified after a proper diagnosis, and it turned out that the opener itself was faulty. Once the issue was confirmed, the opener was replaced with a new one, and everything has been working smoothly since then.:cool:
/ Door opener problem #66
I always mount the sensors above the operator on the mounting brackets, aimed at each other. about a foot apart. Never had a problem with that setup. No kids or animals here.
/ Door opener problem #69
Yes they are, but are a pain in the ass if they get dirty or a bit of debris get on the lenses.
They may be sensors but not safety sensors the way you installed them.
/ Door opener problem #70
The industry standard is 6” from the floor. Any additional sets can be mounted anywhere the customer wants. Fire stations usually have one to see the basket on the ladder truck and one to see the front bumper of all the trucks.
32yrs in the industry…..
2016 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A59230)
2016 Peterbilt 579...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2006 Club Car Carryall 2 Electric Utility Cart (A59228)
2006 Club Car...
2006 Godwin GHP45KW-RC45kW Towable Generator (A59228)
2006 Godwin...
