Don't do what I did
/ Don't do what I did #1
Anonymous Poster
Epic Contributor
Don\'t do what I did
One of my idiot lights on the dash burns out, so I pull the instrument panel out of my L2850 and change the bulb. As long as I'm in there, I might as well clean the inside of the glass panel and the faces of the instruments, right?
So I remove all the screws that hold the surround plastic to the instrument cluster, carefully detach them, and start cleaning the glass on both sides, which is remaining in place inside the surround plastic. It seemed to be glued in there somehow, but it was just held together by 10 years of being bolted together, and the next thing I know, the glass falls out and hits the floor and shatters. I said a bad word.
Okay, a few minutes to cool down, this is no big deal, just gotta get the glass. I might as well go ahead and clean the instrument faces as long as it's apart. Using a soft flannel cloth dabbed in a bit of water, I start carefully wiping to remove the dust and dirt. Well, the white paint from the lettering and tach markings started smearing all over the place! Water was dissolving the damn paint. I couldn't believe it. I took it in the house and used q-tips and got most of it cleaned up, but the white lettering is definitely dulled.
If it ain't broke, don't fix it!
Re: Don\'t do what I did
If you haven't put it back together yet, a gauge shop or glass shop can cut a glass if your dealer can't get one, and I went to the local high school once and the art teacher knew just who would want a job (and had the talent) redoing the numbers on an old car speedo. They were happy to get some paying work and I was flabbergasted by the quality of their work.
/ Don't do what I did #3
Hey, Dummy, I'm still laughing./w3tcompact/icons/laugh.gif But only because that sounds so much like so many of MY projects.
Bird
/ Don't do what I did #4
Now would that be like cooking a stuff turkey and when one returns home after couple of hours only to find I forgot to turn on the oven.
Thomas..NH /w3tcompact/icons/wink.gif
/ Don't do what I did #5
Yeah, like del said, you can probably get the numbers either redone, or just replace the gauge face sheet... if it is a sheet. I'm pretty sure it would be all one on the L2850. Good word of caution if anyone else gets to tinkering. /w3tcompact/icons/smile.gif
/ Don't do what I did #6
Speaking of turkeys..
Hey Thomas, did you ever try grilling a turkey on the BBQ? We have a little domed gas grill. Just big enough to cook a small turkey standing up. If you don't stuff it, but set it up so the hot gasses rise right up that "chimney," in about 1 hr 45 mins you'll have the tastiest bird you can imagine.
Pete
The gauge faces is 3 separate pieces, one each for the fuel, tach, and temp gauge. It looks like to change'em would involve pulling the needles off of each and then carefully removing a couple tiny phillips head screws. It's not that bad, though, since I cleaned off all the white smears there's just a little discoloration on some of the white markings. And honestly, after what I've gone through, I'm a little gun shy, I'm sure if I tried to replace those face plates I'd rip the innards out when I pulled the indicator needles off. So I got a piece of glass cut for $20 and I put it back together as is. I just wanted to warn anyone else, if you're in there, be careful. Who'da thunk the paint on the gauge faces would be water soluble? Certainly never occurred to me.
/ Don't do what I did #8
Yeah, that is probably safe. /w3tcompact/icons/smile.gif I pictured the numbers as smeared... I think I have seen that type of 'paint' before... after it dries out and you add water, you get that mess you described. I'm not sure if the new models use the same paint, though...
/ Don't do what I did #9
Re: Speaking of turkeys..
Pete, that don't sound bad, but is it as good as a Cajun fried turkey. I fried 3 little 12 pounders Sunday morning, 42 minutes each, and don't know how one could taste much better.
Bird
/ Don't do what I did #10
That sounds spicy, Bird. The only disappointment of my marriage is that my lovely bride doesn't like anything hot, except the weather. Having been brought up in SoCal, I love Mexican food. She, being a native Vermonter, thinks Taco Bell is too hot.
Conversely I, having been raised in Southern Cal, simply adore our New England winters. She, having had her fill of cold, hates anything below 60 degrees.
Pete
/ Don't do what I did #11
Yes I tried that matter a fact couple of weeks ago but not on a gas grill,for we cook the wild turkey over apple wood..sure tasted even better.
If I'm lucky enough this spring to harvest another turkey,I sure would like to fry it..for eveyone says its even better...oh this is making me hungry. /w3tcompact/icons/smile.gif
/ Don't do what I did #12
I think we're on the same frequency, Pete, where food's concerned./w3tcompact/icons/laugh.gif I just finished stuffing myself tonight on my wife's homemade enchiladas and tacos. Ate way too much, but still had to top it off with a big piece of pecan pie./w3tcompact/icons/laugh.gif There's lots of recipes for Cajun fried turkeys, but I'm lazy; I just inject them with a pint of store bought Cajun seasoning. I don't consider it hot, but it does give it a mighty good flavor that most folks seem to like; however, I've got one son-in-law who thinks it's too spicy./w3tcompact/icons/smile.gif
Bird
/ Don't do what I did #13
Thomas, I can't recall ever having eaten wild turkey; just the domestic ones. I've wondered whether a wild one might be tough (like an old hen or rooster) unless cooked properly. So I don't know whether they would fry up right or not. I just preheat my peanut oil to 325 degrees, ease the turkey on a rack down into it, bring the temperature back up to 325 and keep it there; total cooking time of 3.5 minutes per pound. Of course, it takes a big pot, and for these little 12 to 14 pound turkeys; 3.5 gallons of peanut oil. I think it's the best turkey I've ever eaten.
Bird
/ Don't do what I did #14
Bird,
I ownly harvest male turkeys,and the young Jakes are a little more tender that the Tom's in the 18 to 26 pound class.
The meat darker and has a gamer taste and seems more filling than a domestic turkey {great Bird you got me to drooling again /w3tcompact/icons/crazy.gif} plus there less grease.
I been check around on turkey cookers and haven't really found one for my needs other than cooking a turkey..would like a cooker for other game also that would stand and open fire.
/ Don't do what I did #15
Muhammad,
I not suprised by Dummy's experience. All automotive and aircraft instruments I've taken apart use a similar paint. I believe its function is to provide luminescence. Note - this type of paint will smear with the lightest touch - even when using a fine brush.
JT
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
20' One-Trip Shipping Container (A66285)
20' One-Trip...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
LEEBOY SUPER 400 DOUBLE DRUM ROLLER (A65053)
LEEBOY SUPER 400...
2014 TOP HAT INDUSTRIES TEREX LIVHT TOWER (A65643)
2014 TOP HAT...
(16) Trimble True Count Clutches (A65640)
(16) Trimble True...
