Don't do it.
/ Don't do it. #42
The T post around the garden I have been able to pull some out by
hand the ornery ones have been using a bumper jack and chain haven't
tryed the tractor quick hitch yet
willy
for t-posts, if i want to keep them i have an amazon special t-post puller that attaches to my FEL and they come right out for the ones i do not intend to reuse i just grab them with the grapple and pull them then go over and stick them back it the ground where they are out of the way.
/ Don't do it. #43
They are called "loader" for a reason.
yes and a hammer is called a hammer for a reason, but they also pry and make good self defense tools also (screwdriver, not so much). The point is it is a tool and there are acceptable uses for a tool and non-acceptable uses for a tool, the difference a lot of times depends on the operator or lack of one.
/ Don't do it. #44
Chaining up the post the draping the chain over the tractor tire then putting the rest of the chin under the tire
Speculating here -- I'd be worried you converted a slipping wheel into a backflip.
/ Don't do it. #45
/ Don't do it. #46
/ Don't do it. #48
This post reminds me of an incident that happened over 40 years ago. A neighbor lady called and asked if I would pull out an old unused fence line. I declined, but not for fear of damaging my tractor.
Her deceased husband had sold off parcels of land for cash, on which he never paid taxes. The guy was a real nut case who was rumored to have buried large amounts of cash all around the farm. The last person to do any work for this lady was falsely accused of uncovering and stealing some of it. He was arrested and the case went to court but was dismissed due to lack of evidence. Cost the guy plenty in lawyer fees though. No way was I going down that rabbit hole!
Over the years, the rumors turned out to be true. After the lady passed away, the farm was sold and the new owner found over $50K buried under the floor of an old barn! Occasionally, I still see people on the land with metal detectors looking for more loot!
/ Don't do it. #49
I know a guy that told me that he has been burying ten grand in cash on his land. He's sealing it up in PVC pipes so it's water and air tight. I really don't know if he is or isn't. He said that he's buried a few of them already, and he's going to bury more of them.
/ Don't do it. #50
I was thinking about this method recently and wondering if you couldn't do the same backing the tractor rear wheel up to the post, Chaining up the post the draping the chain over the tractor tire then putting the rest of the chin under the tire, so moving forward would walk the chain pulling the post up. What think yee?
Surprised this hasn't been mentioned: a post here long ago referenced a kid who died that way, he didn't get the clutch pushed in soon enough before the tractor came back over on him.
And the alternative described by an experienced farmer - chain the post to the front side of a rear tire, back up. No risk of flipping the tractor that way.
/ Don't do it. #52
safer but still puts me and the tractor too close (for me) to the action. using the pull bar that is below the axel center is safe and puts some distance between me and the action, it can still get sporty if the chain breaks or the object comes out too fast but there are risks with everything.
/ Don't do it. #53
My neighbors routinely ask me to do ____ with my tractor. Most think I can dig a deep hole with the loader.
The last request I got was to straddle a concrete irrigation canal and drag an unmounted truck tire on a chain through the culvert that runs under the street.
/ Don't do it. #54
Those videos of clearing out culverts with a rubber tire on a chain are so satisfying to watch! :)
/ Don't do it. #55
I did that with a 40 foot long culvert on my place that wasn't letting water through it. I used two 20ft one inch PVC pipes to push the chain through the culvert, then pulled the tire back through with the hoe on my backhoe.
I was surprised at how easy it was, but I only pulled out about a foot worth of dirt, so it was kind of disappointing. Fortunately I did it in the Spring before the heavy rains hit, and I was very a happy to have that culvert working again!!!
/ Don't do it. #56
You got 3 “good posts” for this idea, so maybe I’m just having a brain cramp.
How do you easily get a fence post lined up in front of your rear tire without first running it over, or at minimum hitting it with your operator platform or platform steps?
/ Don't do it. #57
My brother asked if he should use the L2800 to help my mother's neighbor load some oak logs onto a sawmill. They were 12-16 feet long, and 18+ inches on the small end.
I told him that they weigh more than the tractor does.
/ Don't do it. #58
Even better question is how do you chain it to a tire? I'm not putting a chain through my brand-new wheels and chipping the paint. And rubber lugs certainly aren't going to take the force.
I've seen posts pulled using a tire but not the tire on the tractor. A chain was placed over the top of a loose tire and wheel. Pulling the chain horizontally transferred the pulling force up on the post side of the tire.
/ Don't do it. #59
You are one of the lucky ones that purchased these. There are many complaints that these are cast iron and break easily. I made one out of 1/2" steel flat and even it bent a little. It depends on your soil conditions.
/ Don't do it.
I'm guessing you can wrap the chain around the tire and hook it to itself.
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
PORTA POTTY (A67714)
Renaldo GVB63520-B (A64911)
Renaldo GVB63520-B...
New/Unused Electric Winch (A65583)
New/Unused...
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
2006 PETERBILT 379 (INOPERABLE) (A67714)
2006 PETERBILT 379...
