Dolly for Backhoe?
/ Dolly for Backhoe? #21
I used some HFT Dollies and 2 x 4's
/ Dolly for Backhoe? #22
Nice improvise... but those little diameter casters I think would give me fits. Need pretty smooth surface with no pebbles. My dolly casters are 5in diameter and function very well... I think that is a key design parameter if you build one.
I agree...the larger diameter wheels will make it easier to move on rougher surfaces. As I mentioned I had these hanging around, and being on a smooth surface, the unit can be moved easily.
/ Dolly for Backhoe? #23
Just watch your garage door height...that's what put the stop to my storing inside on a dolly.
My backhoe is a Deere 448. It weights about 1500 lbs, so any dolly would have to be pretty stout. The weight didn't slow me down...but the measurements of the garage door sure did!
/ Dolly for Backhoe? #24
/ Dolly for Backhoe? #25
Awe man, now I got to re-do mine and it's your fault! That's a great idea, never crossed my mind.
Garage isn't very big and that backhoe is about 7ft long sitting on the ground if I remember right. I have to add one wheel to help stabilize it a little more but it works better than I would have thought. I just used steel I had laying around around harbor freight casters.
/ Dolly for Backhoe? #26
This is what I do with mine:
To move it around, you could put it on one or more dollies.
/ Dolly for Backhoe? #27
There is some great looking dollies here, I opted for Bxpanded since I dont have a welder. Mine is inside and on concrete so it made since. Easy to move around to clean up the shed. Since its off 95% of the time I decided to cover it up too. A $20 large motorcycle cover did the trick. This is an old pic and have secured the outriggers better.
/ Dolly for Backhoe? #28
I found a larger wood pallet that I could sit the woods 750 backhoe on, then just move it around with a pallet jack as I have a smooth cement floor in the garage. Couple of 2 x 4 blocks in the right place and it is stable. Cheap and easy!
/ Dolly for Backhoe? #29
Hi folks,
Figured I'd revive the "Dolly for Backhoe" thread now that I'm getting a Woods BH75-1 for my Kubota L3901.
I see some dolly ideas for lighter backhoes (BH75-1 is 840 lb without the bucket), some dolly ideas that require welding (which I'm not equipped to do), and I see dangier_VA's idea with the pallet and jack (but pallet jacks aren't cheap). Has anyone out there built a dolly capable of holding a thousand pounds of backhoe+bucket and which does not require welding or the purchase of a pallet jack? I would be using this dolly exclusively in a barn with a smooth concrete floor. Thanks in advance!
/ Dolly for Backhoe? #30
I believe my Backhoe attachment is over 1500 lb, I used HFT Dollies and 2 x 4's
/ Dolly for Backhoe? #31
I had a lighter bh and made a dolly using 3 moving furniture dollies and some 2x4 to hold them together. The rig would move on cement if the floor was very clean Lowes sells the furniture dollies I prefer the wood as the plastic has a tendency to break. Good luck
207275 (A52708)
207275 (A52708)
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
2021 Kubota SVL75-2 Track Loader (A63118)
2021 Kubota...
2005 John Deere 7320 (A60462)
2005 John Deere...
Case Titan 3530 (A63118)
Case Titan 3530...
2006 Hitch and Trailers Inc. 12ft S/A Utility Trailer (A61574)
2006 Hitch and...
