Does Propane go bad?
/ Does Propane go bad? #1
HawkinsHollow
SE TN
Branson 3015R
I have a 100 pound tank that I inherited with my property 4 years ago. No idea how long it had been sitting there before I bought the place. It has maybe 40 pounds of propane in it. My gut tells me that I am good to use it, but my question is... Does propane go bad? Discuss!
/ Does Propane go bad? #3
The propane should be just fine. Propane can last years. But do a visual on the tank to insure no rust and good integrity of the tanks valve.
Thanks y'all! Yeah tank looks fine, but I will inspect bottom closer to make sure.
/ Does Propane go bad? #6
How old is the tank? If you inherited it the tank may be many years old.
It can't be that old, because it is in pretty decent shape. I've had it 4 years and quickly got it out of the weather.
/ Does Propane go bad? #8
Wish I could say the same, I have two 100 pounders on my property left by the former owner. Might have to hike up there and take a gander at them. ;-)
/ Does Propane go bad? #9
If you are a fuel seller then yes it goes bad..and you need to buy a new tank every 10 years.
/ Does Propane go bad? #10
You can also get the tank recertified. Most folks just don't bother and just buy a replacement at a higher cost than recertification.
/ Does Propane go bad? #11
I've never heard of propane going bad for a homeowner. I do know if it gets cold enough ( below -44F ) the propane will remain in liquid form and not produce vapor pressures. Our 100# propane tank was in a small enclosure with a heat lamp when we lived in Glennallen, AK. On with the heat lamp - wait five minuets - the gas kitchen stove would then work. The tank would begin loosing pressure around -15F.
/ Does Propane go bad? #12
The industry uses propane often for 6 years or more between turnarounds (maintenance shutdowns). It does not degrade.
Propylene might react with other things, but propane is pretty much inert. Again, industry uses closed circuit propylene refrigeration for 6 years or more with no problems and going through rather extreme temperature cycles from -40 F up to about 220 F.
/ Does Propane go bad? #13
They aren't 'tanks' anyway. The correct term is 'Bottle'. Tanks are always non pressurized containers. Bottles are pressurized. Here in the states you get them recertified every 10 years (just like pressurized welding and medical gas bottles). Tanks don't require any certifications other that be built to ASTM specs prior to sale.
/ Does Propane go bad? #15
100LB cylinders is the correct term. A DOT cylinder is sold by the weight so a 100LB cylinder holds about 23 lbs of propane propane weighs 4.23 lbs / gallon. An ASME tank / vessel is sold by the gallons. Tanks are a pressurized vessel built to ASME standards. The relief valves for DOT vs ASME have different set points.
That is why they call them SCUBA bottles right?
/ Does Propane go bad? #17
Depends on who you talk to... All I did was put down the correct terms as they relate to tanks and bottles. I really don't care one way or another what you call them.
Like the venerable 'Crescent Wrench' Not a Crescent Wrench but an adjustable open end wrench. Crescent is the name of a Tool company.
Kind of like all the different names for a turd..... :p
Exactly!! Then why comment?
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63688)
2019 Cadillac XTS...
2022 John Deere 7R 210 Tractor (A63111)
2022 John Deere 7R...
2025 Quick Hitch Skid Steer Attachment (A61572)
2025 Quick Hitch...
2020 VOLVO VNL840 MIDROOF 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 VOLVO VNL840...
207272 (A52708)
207272 (A52708)
2007 FREIGHTLINER M2 4X2 S/A STAKE BED TRUCK (A59912)
2007 FREIGHTLINER...
