Does building log splitter make $ sense
/ Does building log splitter make $ sense #51
To be honest, I have rented for the last couple of years. I usually get a 20ton log truck load and work it up myself. It took 2 days as hard as I could go, with a helper to process that log truck load of logs. I know all to well about trying to get it all done in one wkend. WHEW!.
I built a splitter back in the early 80's using a 4inch cyl and a 3gal min pump. That thing would shear wood sideways if that was what I wanted. I moved and sold the splitter since the house I bought didnt have a chimmely. I sold and moved again a few years ago into another house with full basement and woodstove. I am just now getting around to building another splitter. I simply like being able to work my wood when I want to and not when I have to.
I cobbled together a homemade splitter I bought for $75. It had a 6.5in x32inch stroke cyl on a very thin Ibeam that just isnt holding up to well. I used a PTO pump system off a longarm mower to supply the hydraulics. I dont know the flow or the pressure, but its way more than the Ibeam can handle with a 4way wedge. My intent was to try and get by this winter while i build a decent splitter, but so far I have spent more time welding on that durn thing than splitting. I finally gave up last wkend and started on my new splitter. I'll probably start a thread with pics once I get it all built. The only thing I will have to buy will be the 28gpm pump, ( I already have several single stage pumps I could use) I have 3- 25hp kholers setting around not being used, a 6x6hbeam, cylinders, and 1in plate, as well as the tank and control valves off the splitter I will be scrapping out. I will need to buy a coupling for the pump shaft and a few hyd hoses and then make the splitters fly.
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
Kubota L3130 (A53317)
2022 Horizon Trailer (A55973)
2022 Horizon...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2019 Toro Dingo TX525 Mini Skid Steer (A60462)
2019 Toro Dingo...
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
