does anyone have a JD1050
   / does anyone have a JD1050 #1
garry
Bronze Member
Ohio
JD 1050
Does anyon here have a JD1050 4x4 with ag or R4 tires. If so what size are they (frount and rear).
I would like to swap my turf tires for something with a little more bite but I'm not sure what size I should be looking for. I would be looking on the used market for both tires and wheels.
Also would anyone know of a good source for used tires, maybe a dealer that keeps a used tire and wheel inventory in the NE ohio area.
   / does anyone have a JD1050 #2
Re: doe anyone have a JD1050
A 1050 with 4x4 would have had 7-16 front and 13.6 x 28 rears, you're gonna need tires and rims to keep the ratios correct to prevent front axle damage
thanks Joe
   / does anyone have a JD1050 #4
I suspect you will have a hard time finding used wheels. I have a 950 with same 7-16 front. My front wheels have rusted out somewhat around the valve stem. I think it set out in the weather in a previous life. I have looked quite a bit trying to find used wheels with no success. I tried searching n google for tractor salvage yards. Found many, called/e-mailed several. No luck. /forums/images/graemlins/frown.gif If you find 2 sets, let me know. /forums/images/graemlins/smirk.gif
BB, what size are the rear tires on your 950
Would Ag tires and R4's use the same wheel?
   / does anyone have a JD1050 #7
<font color="blue"> BB, what size are the rear tires on your 950 </font>
I want to say that they are the 13.6x28 as is yours. But my tractor is about 30 miles away and I can't verify that right away. I do have ags on mine. I don't know the actual wheel sizes.
   / does anyone have a JD1050 #8
I have a JD 4100 and I had the dealer switch out the ags to r4s, they used the same wheels.
   / does anyone have a JD1050 #9
This is NE Indiana but I know Zurcher Tire in Monroe, IN has rims for what you (or anyone) would need. They'll even paint them Deere yellow for you.
Good luck with your 1050. I think it's one of JD's best ever. I hope this helps. /forums/images/graemlins/smile.gif
   / does anyone have a JD1050 #10
They're the same... A 1050 is a turbo'd 950.
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2019 FORD E350 16FT BOX TRUCK (A59575)
2019 FORD E350...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
