Does 4WD Make That Much Difference
/ Does 4WD Make That Much Difference #51
97% of the time, no. 3% of the time is worth every bit of it. Unless you are sure you will on dry and flat ground during the summer, 4WD is worth it.
/ Does 4WD Make That Much Difference #53
Danger of not being able to back up.
I would think there are particulars before a blanket statement is made such as "no 2wd should be sold with a fel". There are plenty of milk farmers with 2wd and fels in my parts that would question the veracity of such a statement.
/ Does 4WD Make That Much Difference #54
The most important thing to me with a fel is rear ballast. Hundreds of thousands of 2 wd tractors out there with fel's
/ Does 4WD Make That Much Difference #55
MFWD / 4x4
PROS...
--going into a turn... you keep turning vs front wheels acting like skies and just keep going straight.
--getting you through a "wet patch" if just 2WD, you hit wet patch you are stuck. hopefully with 4WD you can maintain enough traction to keep going.
--more likely keep you going straight... how many times have you had a rear blade, or something else behind tractor and pulling it. and one side gets loaded down... to point it starts pulling the front end around on you? and you are having to turn the front wheels (on 2WD) tractor or perhaps tap split brakes (rear left/right brakes) to keep going straight? MFWD / 4x4 should keep you going.
CONS...
--you may need to change front tires and rear tires at same time. due to "ratio" issues of tires being within a certain tolerance. if tolerance gets out of whack you are at higher risk of doing damage to the drive train / system of the MFWD / 4x4 function of tractor.
--costs more up front
--cost more long haul (maintenance side of things)
--you need to remember to take MFWD / 4x4 out of gear. on pavement / concrete / hard surfaces. or you can damage the drive train as well as tire treads wear quicker when in MFWD / 4x4 and on hard surfaces.
MISC....
MFWD / 4x4 tractors might be ballasted / weighted differently. in order to take advantage of MFWD / 4x4 function of tractor when pulling stuff.
keep in mind what is more important to you.... field work = money making? duals on older 2WD tractor for flotation / less compaction. and larger machine might serve you better?
or is just a general multi purpose machine what you need? more like smaller machine with MFWD option and some additional smaller addon's to make life easier and simplier for you.
goto the various tractor manufacture websites out there and go through there "build a tractor / configure a tractor / what ever they call it" and familiarize yourself with the "additional options" for different make/model of tractors even from same/different manufactures.
www.tractorhouse.com = while a lot of used tractors show up in lists, there are some new tractors as well. more of goal to use as a "research tool" / doing your home work of see what is out there.
SearchTempest: Search all of Craigslist nationwide & more = search multi cities of craigslist .org at one time. some additional things locally normally show up.
Tractor Attachments And Skid Steer Attachments For Any Tractor Or Skid Steer = just "attachments" for tractors. last time i looked they did not hit heavy in larger farming operation equipment. they do have a lot of various equipment. (good starting place to see what is out there) lots of videos / details of what things do / how to use them.
goto a few local dealers in your area. and set in different size machines and test drive each one. for say 15 minutes. if they have something you can hook up to it. or perhaps a FEL you could use to push some dirt around. might be advised. there can be a large difference in how things are laid out as far as controls on tractor. and overall power factor / feel to things.
--most tractor manufacture websites have some sort of "dealer locator" enter zip code and find. (starting point)
--look up in old phone book for "heavy equipment" to "tractors" to "farm equipment" there might be some local mom / pop shops around. that may not show up.
/ Does 4WD Make That Much Difference #56
MFWD / 4x4
PROS...
CONS...
MISC....
Got most of the cons, but WAY short on the pros. The pros would be broadly based in every motive tractor function.
/ Does 4WD Make That Much Difference #57
I was pushing brush down a hill today that was pretty steep. I knocked the tractor out of 4wd and tried to back up the hill. It just spun, and this had the best possible chance of working. I had loaded tires, a backhoe attachment which adds significant ballast, and no load on the FEL. I put the tractor back in 4wd and it backed out without any trouble. If a tractor has a loader it should be 4wd. If a tractor does not have a loader and is going to be used on mostly flat ground I think a larger 2wd would be fine.
/ Does 4WD Make That Much Difference #58
Spot on 4570Man! If you HAVE hills and/or FEL... 4WD a must IMO!!!
/ Does 4WD Make That Much Difference #59
For the hobby guys on here that have one tractor, 4WD can make the most sense. They seldom have farmable land, and have lots of slopes, ponds, etc. For the farmers on here that make their living with their tractors and harvest crops mostly on flat ground, 2WD combined with some 4WD where needed makes a lot of sense. No sense a farmer listening to a <10acre hobby guy, who sits inside when the weather is bad, on what tractor works the best. No sense a farmer with 100s or 1000s of acres and a crop and paycheck to bring in, listening to a hobby guy on what tractor works the best. No sense a hobby guy listening to a farmer on what makes sense, The hobby guy does not need a tractor that works primarily on flat ground. To each his own and neither is wrong.
/ Does 4WD Make That Much Difference #60
For the hobby guys on here that have one tractor, 4WD can make the most sense. They seldom have farmable land, and have lots of slopes, ponds, etc. For the farmers on here that make their living with their tractors and harvest crops mostly on flat ground, 2WD combined with some 4WD where needed makes a lot of sense. No sense a farmer listening to a <10acre hobby guy, who sits inside when the weather is bad, on what tractor works the best. No sense a farmer with 100s or 1000s of acres and a crop and paycheck to bring in, listening to a hobby guy on what tractor works the best. To each his own and neither is wrong.
Well said.
2016 BOBCAT T740 SKID STEER (A62129)
2016 BOBCAT T740...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
1660 (A59213)
1660 (A59213)
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
2025 Kubota KX040-5 (A60462)
2025 Kubota...
