Do you think it is possible???
   / Do you think it is possible??? #1
horticattleman
South Central Louisiana
CT335
I have a tiller for a 425 but have never really used it. Do you think it is possible to convert it to a ditch filler????
   / Do you think it is possible??? #2
Sure. Just replace the tines with left & right hand augers.
   / Do you think it is possible??? #3
Why not just make a V shaped pusher blade and weld it to a QA plate. Shape the blade so it leaves a small mound over the trench. or leave the back of the V open for the hill effect. Could also have a wheel behind the V to compress the dirt into the trench
4 steps ahead of you. I have made that already as well as a flat angles one with a shoe and they work pretty well, except in S. Louisiana we have some soils that are very clay type and once the spoil sits exposed for more than a few hours it becomes hard. We use small cultivators to break it up buty its time consuming.
Can I buy just the auger spindles? Guess thats a Kieth question huh?
   / Do you think it is possible??? #6
I don't know if Keith will be the best resource for that question. He knows his PT parts, but this is a little off the wall.
I've seen such augers in both agricultural and industrial settings. I'd start looking at agri-supply.com and mcmaster.com
2016 Ford F150 Ext. Cab Pickup Truck (A50323)
2016 Ford F150...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
Small concrete mixer (A49461)
Small concrete...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
1267 (A50490)
1267 (A50490)
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
