Do you hate your rotary cutter gearbox shield?
   / Do you hate your rotary cutter gearbox shield? #41
My bush hog cover does not have the cool EA logo so it is different. :ROFLMAO:
My Bush Hog BH15 (2017) came with the aggravating plastic bell cover. I got the EA one painted yesterday. Maybe I’ll start the swap out today. It appears I will have to remove the driveline from the splined gearbox shaft to remove the old plastic one.
EDIT: Measure carefully. I did my best to measure with the plastic shield on before ordering the 2 7/8 inch one. After removing the plastic junk one today I found mine is really 2 5/8 inches. Working on a solution. The EA shield is pretty stout metal.
   / Do you hate your rotary cutter gearbox shield? #43
Kind of unpleasantly surprised that LP don't redesign their shielding. The way they are presently, greasing the U joint in front of the gearbox or slipping the clutch is a royal PITA.
   / Do you hate your rotary cutter gearbox shield? #44
Not really. Just cut it off with a sawzall. You won't ever use it again so it goes in the trash. Gonna order one but not now. It's winter here and I won't refit until warm weather comes again.
   / Do you hate your rotary cutter gearbox shield? #45
I don't have an EA but that's what I had to do for the last covered PTO shaft I got. I cut the tractor side because it was hard for me to get to the release. I cut about 2" off the bell which is about where the last flare ends. Works great now.
Over the years, I've compiled quite a collection of ongoing land pride failures, and based on them not redesigning many common issues with their attachments, I don't think this area is even remotely in their scope of things to improve..
Travis
   / Do you hate your rotary cutter gearbox shield? #47
EA...maybe instead of 4 mounting holes have 4 slots. That way any bolt pattern between the 2-3/8 and 2-7/8 would work, even the odd "metric" ones.
   / Do you hate your rotary cutter gearbox shield? #48
Land Pride isn't the only one. It saves a buck on each implement built but makes it a pain for the owner to maintain. I hate servicing the u-joint and slip clutch every year because of the poorly designed/implemented shield.
   / Do you hate your rotary cutter gearbox shield? #49
I don't 'hate' it. In reality I don't 'hate' anyone or anything. That word is used way too loosely. I find it inconvenient
   / Do you hate your rotary cutter gearbox shield? #50
Travis
Never had a failure of any LP implement I own. In fact, both my 3 point shredder and my batwing mower are overbuilt.
2022 Behnke Trailer (A55973)
2022 Behnke...
CAT 350E2 Haul Truck (A55272)
CAT 350E2 Haul...
2009 Honda odyssey (A55788)
2009 Honda odyssey...
2023 CORAS PREDATOR 28FT DUMP TRAILER (A58018)
2023 CORAS...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
PALLET OF MOWER BLADES & MISC PARTS (A58374)
PALLET OF MOWER...
