Do Trickle Chargers Really work....
/ Do Trickle Chargers Really work....
JJ, there are diodes that are made to allow "reverse" voltage, ie breakdown voltage for specific circuits.
These are called zener diodes.
/ Do Trickle Chargers Really work.... #42
I use optimates.
This is the latest generation.
http://www.optimate1.com/optimate-6-ampmatic
They are the best chargers I've ever used to preserve and restore dead batteries. This video shows an optimate 4 smoke the self=proclaimed best smart charger in the world from eight years ago. Optimate has two newer generations now and they all work awesome.
I don't want to contradict anything in this post, but I watched the video and consider it a fluff piece. It is attacking the CTEK, yet both chargers hold the battery at 12.89 volts. When the Optimate does that they say it is good, when the CTEK does that they say it isn't fully charged yet. I think they are playing on people's ignorance of how the two chargers are designed to work. They aren't actually comparing the quality of job done by either.
And yes, I have used multiple CTEKs for years, so I probably do have a bias. But I don't know 'how well' any of these work, I just know what I've read in reviews and what I have experienced. I'm sure I'd like the Optimate, too. But I don't like their comparison video. "Cheap Shot" in my opinion.
/ Do Trickle Chargers Really work.... #43
The CTEK charged, then stopped. The optimate when it stopped charging, the battery held the charge.
I've taken lead-acid batteries that couldn't hold a charge and restored them with the optimates. I've had a very positive experience with them over the last 15 years.
/ Do Trickle Chargers Really work.... #44
Read post #3, mine does have "float" on it also.
Okey Dokey. I'm a big fan of the $5.99 harbor freight float chargers - they do the job and I'm running a half-dozen of them at any given moment, although I've had to modify many of them to produce a more desirable float voltage.
/ Do Trickle Chargers Really work.... #45
They can extend the life of a battery that may sit partially discharged for a time. A worthwhile tool for any vehicle owner.
/ Do Trickle Chargers Really work.... #46
The Genius chargers will bring back most bad batteries.
/ Do Trickle Chargers Really work.... #47
Interesting... makes me want to buy one just to see if I can resurrect a couple old dead 12v batteries.
/ Do Trickle Chargers Really work.... #48
I have several Noco genuis chargers. I have revived several batteries with them. My second choice for a charger would be a CTEK.
/ Do Trickle Chargers Really work.... #49
I've been using the Deltran Battery Tender Plus for my tractor and generator. Wondering now if I could've/should've saved a few bucks and bought the Junior version for half the price? I see the difference is 1.25amp vs .75amp charging but I am guessing the rest of the guts might be a bit better quality and last longer... :confused3:
/ Do Trickle Chargers Really work.... #50
I think the Junior is the entry level one made to compete with the off brand chargers.
/ Do Trickle Chargers Really work.... #51
Another fan of the Noco genuis chargers.
Typically they go on sale (~50%) at Canadian Tire every 2 to 3 months.
Cheers!
-- Bill --
/ Do Trickle Chargers Really work.... #52
If you let an optimate sit on a dead battery long enough, it will come back. Case in point: 1987 escort still had the OEM motor craft battery in it when I scrapped it in 2005.
Downside: these Optimate 6s are a little over $100 bucks now, and FWIW, CTEK also has a good reputation.
/ Do Trickle Chargers Really work.... #53
They may very well be entry level, but they work very well. Just as good as the Battery Tender Plus. If I remember correctly I have 5 Tender Jr's and one Tender Plus. The five tenders are all more than 5yrs old. A couple are closer to 8 or 9 years old. I have them all all the toys I don't use on a regular basis.
/ Do Trickle Chargers Really work.... #54
TSC had trickles on sale for 7.99 . I bought 6. Gave my kid 2. I have one on my lawn tractor, one with a permanent plug on my Mahindra, one on my Dad's JD lawn tractor and one on my FIL car.
What a difference a warm battery makes.
My 89 yo FIL doesn't drive his car any more but won't get rid of it. It sits beside my barn, constantly in the way. It was parked there last October with Stabil added and a TSC trickler on it. It hasn't been touched until today.
I had to get around the back of my barn and his car was in the way. I had to dig it out of nearly 4 feet of snow and drag it clear with my tractor. It's been sitting all winter in sub zero temps and it started as if it was July and just parked overnight.
A warm battery makes a happy car/truck/tractor.
/ Do Trickle Chargers Really work.... #55
As far as a battery discharging with a battery connected, but not plugged into AC, my thoughts on this is, that it would be hard to know if the battery was self discharging or a small current was flowing through the charging circuit.
I know DC chargers have a diode in the circuit, but is there any leakage through the diode?
Even if a battery is not connected to anything, most will self discharge.
I am sure some smart guy is going to take a meter and see if there is any flow with the battery charger not plugged in.
My thoughts is that a high dollar precision diode would not allow reverse current.
If the diode is not so good, then it may be possible for a small current to flow and n time would discharge the battery.
Alrighty now, just don't beat me up
Excerpt: Diode
The key function of an ideal diode is to control the direction of current-flow. Current passing through a diode can only go in one direction, called the forward direction. Current trying to flow the reverse direction is blocked. They are like the one-way valve of electronics.
If the voltage across a diode is negative, no current can flow, and the ideal diode looks like an open circuit. In such a situation, the diode is said to be off or reverse biased.
As long as the voltage across the diode is negative, it will t麹urn on and conduct current. Ideally, a diode would act like a short circuit (0V across it) if it was conducting current. When a diode is conducting current it is forward biased (electronics jargon for 逋サn?.
Most all golf cart batteries discharge 5% - 10% PER MONTH, when just sitting idle.
/ Do Trickle Chargers Really work.... #56
Waste of money if you ask me. I bought one that plugs into the cigarette lighter/power outlet and it didn't work worth a damm!!
/ Do Trickle Chargers Really work.... #57
Must have been a blown fuse or something :D
/ Do Trickle Chargers Really work.... #58
Is your power outlet powered when the key is off? If it isn't, that charger won't do anything.
I have a Battery Tender Plus for gel cell batteries:
Amazon.com: Battery Tender 021-0156 Battery Tender Plus 12V Battery Charger True Gel Cell Model: Automotive
If I park the Lotus for more than a few weeks and I've forgotten to plug it in, I'll have a dead battery. If I have the tender hooked up, it's ready to roll anytime. I didn't have a tender for the first few years I had the car and I replaced the battery every spring because it was dead and I couldn't resurrect it. Now, the battery seems to last forever.
/ Do Trickle Chargers Really work.... #60
I've lost the link, but a couple years ago there was a good discussion and easy instructions on building a 120V ac battery "reinvigorater" with a cheap (rectifying )diode and a couple light bulbs that splits the voltage (or maybe limits the current), but the claim was (if I remember) it re-suspends the metals(?)/minerals(?) that fall out of the electrolyte and shorts the battery plates. That with this device (and occasional electrolyte refreshment) the battery will last forever.
The claim being that the life of the battery is mostly determined by how much space is at the bottom of the battery to accommodate the metals that fall out of the solution until they short the plates.
Ahh... here it is: http://www.tractorbynet.com/forums/owning-operating/166271-battery-rejuvenator.html?highlight=battery+reinvogorater
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2022 EZ-GO ELITE...
2018 Freightliner Cascadia 125 Truck T/A Sleeper Cab Truck Tractor (A64194)
2018 Freightliner...
Unused Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Unused Michelin...
W.R. LONG FAST HITCH FORKS (A64278)
W.R. LONG FAST...
2020 FREIGHTLINER M2 4X2 S/A 26FT CDL REQUIRED CURTAINSIDE BOX TRUCK (A67148)
2020 FREIGHTLINER...
