Do tire studs work?
/ Do tire studs work? #1
sqdqo
Marquette Michigan
Massey Ferguson 492 w/Quicke Q750 loader
Does anyone have experience with tractor tire studs? Do they work or are they a waste of time and money?
/ Do tire studs work? #2
All depends on you wallet more than anything,
Where you are a set of 2 row snow chains or
2 row V chains would last you forever and always
be able to handle the work.
I loaded the rears on my lawn tractor as the chains and
rear suit case weights alone were worthless.
Load your rears and buy a set of chains and you will be better off as
studded tires on tractors will behave just like studded tires on cars
with black ice to deal with-only as good as your tractor and implement weight.
Reminds me of a cartoon by Larson years ago where farmer had a tractor and a
huge set of drags consisting of 30 plus cats with their claws all stuck out and
being dragged by the tractor.
The issue is traction and only traction. the studs are only as good as the
snow or ice covered ground they travel over.
/ Do tire studs work? #4
I'd like to think they help when driving on the highway on snow/ice, especially when going around curves.
H
My tractor has loaded rears. Tractor weight is around 12k. I have a snow blade on the loader and the front of the tractor slides around. I was wondering if studs would be good enough to keep it straight
/ Do tire studs work? #6
I have thought about studs, but my concern is where they will end up if/when they fall out.
/ Do tire studs work? #7
/ Do tire studs work? #8
They sure do work but not as well as chains. Here is a video about studs in my r14 tractor tires where I driveway test r14 with studs.
Testing the R14 tractor tires on snow covered driveways
UNUSED WOLVERINE MAD-12-12D (A64281)
UNUSED WOLVERINE...
2007 FREIGHTLINER M2 4X2 S/A STAKE BED TRUCK (A59912)
2007 FREIGHTLINER...
2022 CATERPILLAR 299D3 XE SKID STEER (A64279)
2022 CATERPILLAR...
Colombo CTA 6500 (A64119)
Colombo CTA 6500...
2020 ATLAS 2 POST AUTOMOTIVE LIFT (A59912)
2020 ATLAS 2 POST...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
