Do I need tire chains for upcoming winter?
/ Do I need tire chains for upcoming winter? #1
Todd_C
Southwest, VA
New Holland TC 40A
I purchased my first tractor in August. I bought a TC-30 with FEL and filled R4s. I live in a mountainous area in Southwest Virginia. It snows several times during the winter season. I will be using my tractor and a 6' Linebaugh rear blade to keep my driveway cleared. Most of the snow totals are under 8", but we do get a few heavier snow falls. I live almost a mile off the pavement on a gravel road. I live on a ridge top. Last year we were burdened with several ice storms. There were a few days my 4x4 pickup couldn't get out.
Should I consider purchasing a set or rear chains?
/ Do I need tire chains for upcoming winter? #2
I'd suggest trying without the chains first. I never had any need for 'em.
I doubt if snow will give you any problems...
However, icy conditions do require some kind of chains or studs. There's one guy on TBN that installs screws in the bars of his tires (makes 'em studded).
So..suggest you try the first winter without chains...you may well want to get them later..or, you may find out you don't need them.
Anyway...not much you're going to do on an iced up road with a tractor...
/ Do I need tire chains for upcoming winter? #3
I'm going to disagree with Roy.
$100 well spent BEFORE you need them. If you don't consider it a cheap insurance policy.
Check out tirechains.com
More choices than you can shake a stick at:
Ladder (basic tire chain) get the "2 link" more cross chains than the 4 link = "smoother" ride
Dou-grip - X shaped cross chains, better sideways grip, but bumpy ride.
Either of the above is available with spikes. Great for a gravel drive, but will shred a paved one.
I've got the duo-grip. Never got stuck without them, but they sure made plowing my hill quicker...
Try a search here on tire chains - you will get plenty of hits (be sure to set the date range back far enough to cover last winter)
/ Do I need tire chains for upcoming winter? #4
Contrary to Roy's experience (I'm also in PA) I do need chains on my R4s in winter. At least I did up till now. I guess I probably still do, but changed the grade a little getting up from my shed, so it is a little less severe.
Heck, I needed chains all summer for that matter. I took them off in May and put them back on in June. Too much rain making things slick.
You have to ask yourself if you don't get them, and find you need them, can you afford to wait however long it take to order them and have them in your hands?
If the answer is yes, then why not try without them and see what happens? If the answer is no, then order them and you will have them if you need them, or you can just put them on in advance.
When reading your question, my gut was telling me you need chains. But who knows? Be aware that in the wet fall and wet spring, grassy slopes can turn into scary situations, with ice like slides happening with little or no warning. That is what convenienced me to get chains to begin with, more than my worry that snow might require them.
If you can afford to spring for a set of $ 200 a pair chains, it might just make sense to buy them in advance...
/ Do I need tire chains for upcoming winter? #5
"Be aware that in the wet fall and wet spring, grassy slopes can turn into scary situations, with ice like slides happening with little or no warning."
Boy..ain't that the truth!!! Man, wet grass is something to stay off of!
But I don't operate on the grasses when it's wet...tears the grass up big time...chains would tear it up more!
Henro, of course, is in western PA. I'm in south central PA. We get a few snows a year..normally one blizzard every 3 to 5 years (30" plus). And, about once a decade we get a real tough winter...frequent snows and freeze ups. Henro's area normally gets hit harder every year.
I thought about chains...just never had any situations I needed 'em.
/ Do I need tire chains for upcoming winter? #6
I just ordered a set of the ladder type for the rear of my Cub 7275. They are not cheap with the tensioners. But I figured that I need them more than ever to do work around the farm. "TireChain.com" was the cheapest place I could find to buy them.
/ Do I need tire chains for upcoming winter? #7
Todd
Whether you need chains or not cannot be changed if winter comes and you do not have a set when needed.
I have chains for my tractor. Never used them.
My previous tractor had chains, did not use them for about 10 years. Then a storm came that had freezing rain and about 6" of snow on top. Tractor would not move a foot without getting stuck. Went back to barn and put chains on. Completed clearing snow with no more problems.
If I did not have chains that day. I would have not been able to clear my driveway.
/ Do I need tire chains for upcoming winter? #8
<font color="blue"> </font> There were a few days my 4x4 pickup couldn't get out.
Perhaps you have your answere with that statement.
Egon
/ Do I need tire chains for upcoming winter? #9
I live further north, see lots of snow and have a section of driveway that is moderately steep. For 4 years I cleared snow without chains. Late in year I got stuck fairly bad, (I got out under my own power, but it took some work). I picked up a set of ring chains, and the difference is amazing. I'll put them on when the ground freezes, and take them off in the spring. People plowing have more of a need for chains, because they need all the traction they can get. With the blower, I'm sure I could get by without the chains, but they sure help when the snow gets deep, or if it gets icy.
/ Do I need tire chains for upcoming winter? #10
Ron- I think you hit the nail squarely on the head. We use chains on both our botas here in VT and I also have a set for the front of my 2410 that I hope I will not need to use, but it feels good knowing that they can be on if needed in 10 minutes!!!
If the storm comes and you decide you need them- they are there and on in 15 minutes OR you decide you need them and they arrive in the brown truck a week and a half later!!!
Thanks for eveyones input. I went to tirechains.com and now I am attempting to decide on which style of chain I need. I don't think I will use the chains a lot, so would the standard Ladder chain work ($121) or should I get the Ladder chain with V-bars ($164).
/ Do I need tire chains for upcoming winter? #12
Todd
For R-4s and R-1s I would recommend DUO-GRIP TRACTOR TIRE CHAINS from TireChains.com.
They don't offer the duogrip chain for my R4 tire size (15-19.5).
/ Do I need tire chains for upcoming winter? #14
Todd
If spending over $200 is not a problem then go with the 2-Link Spacing Ladder. This will give a smoother ride. The V-bar type chains will mark concrete and blacktop worse than just plain ladder.
/ Do I need tire chains for upcoming winter? #15
If you have a slope to climb, you'll likely need chains.
I have a Gravely on which I've used chains on 2 single turfs, dual turf without chains and now dual ag tires with studs. Haven't had much opportunity to use the dual ag tires with studs yet. Definitely have to use the chains for pushing the snow thrower or for pushing the snow plow in sloppy conditions if I want a full width (4') bite.
I did hang up a chain on one wheel because I didn't secure some excess chain and broke a link. After that, I used it with the dual turfs and took small bites with the snow plow. Didn't get a chance to use the new ag tires with studs last winter.
For this first winter with my JD 4010, it's parked in the basement of the carriage house, down slope from my driveway. The Gravely with plow and dual ag tires with the studs is in the carriage house at driveway level. NO WAY without chains would IT go up and down that slope to the basement area. Remains to be seen whether I'll need the JD and its loader and whether I can get it up the slope without chains.
Ralph
I hate to accept the facts, but I should go ahead and spend the money. I drove my ATV out of the drive last year after an ice storm and immediately did a 360. It was fun after the ride was over. My house and drive in front of my house is on level ground, but the trip to my house is up a constant grade. I don't want to take a chance on the tractor. I would hate to slide off the edge of the road to my house while plowing snow.
/ Do I need tire chains for upcoming winter? #17
I had chains with turfs on a Deere 318 GT. Worked great. On the new kubota 2230 I bought chains also. I am in Kansas city and we get reasonable snow but not like the Northeast. however, I need turfs due to thin grass and the need to maintain my turf... however, my storage area and wood pyles are in the woods at the bottom of a steep incline. I would never make it up with a full load and no chains.
I ordered them and got them on Tuesday. Wed morning we got 6 wet heavy inches of snow. i did not put the chains on so I could see how the turfs do with 4x4 only. Well it pushed and pulled now fine but I did need the 4x4 and got stuck on a slight incline that was packed snow. Had to go forward throught he grass in order to get out.
I am glad I got the chains as they will come in handy for winder and any heavy BB or Loader work.
/ Do I need tire chains for upcoming winter? #18
Charlottesville, VA, USA
does it snow in this area ??/
/forums/images/graemlins/grin.gif
/ Do I need tire chains for upcoming winter? #19
Some people advocate chains on the front for better control if you are 4wd. Would this suffice instead of the rear? Also, might be less expensive since they are smaller.
/ Do I need tire chains for upcoming winter? #20
If you're going to chain up a single axle, make it the rear. Chains on the front only, will do nothing for braking and will put undue stress on the front end.
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
2016 JOHN DEERE 35G EXCAVATOR (A60429)
2016 JOHN DEERE...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
2010 Toyota Highlander SUV (A59231)
2010 Toyota...
