Do I need a tractor?!
/ Do I need a tractor?! #21
Do you need a tractor, no. All you need to do is breath and eat. However if you want to do more than that you'll really want one. Unless you feel comfortable searching the internet to buy parts I would see what's around you for dealers. It's not going to do you much good to have a tractor that needs parts and the closest dealer is 100 miles away. Dealers may not always be the best price but a lot of time you can walk in and pick their brains (like you can do here).
I wouldn't avoid an older tractor as long as it looks in somewhat good shape. If you look it over look for things like welds that don't look like factory or aren't on the same on each side. Look for pins and bushings that look overly worn, a sign that someone didn't take care of the tractor enough to keep things greased (who knows what else they didn't keep on top of). Fresh paint would also be a sign to look closer.
My Neighbor has an old Yanmar that was welded back together after it snapped in two. It has been worked hard and put up wet yet keeps coming back for more. He bought it for $1000 and figured it was cheap enough that he would hope it held up. So far it's more than paid for itself.
/ Do I need a tractor?! #22
He is right... Just keep looking. I found a 2005 Kubota B7510 276 hours on it with a loader and box blade and a Trailer for 6K... Yesterday I bought a used 4 foot J-Bar Bushhog for $300... All on Craigslist.
There are deals out there to be had. Just keep looking...
276 hours for $6k with a box blade, loader and trailer...now -that's- a good deal. The seller must have been desperate or something because he could have gotten far more than that for that setup! I'll bet you smile every time you start that baby up....!
And as for needing a tractor, I'd say with 10 acres and horses, plus hauling logs, I can't say anything else but "yes" to that question. Then once you get it, you can come up in here and see all the cool stuff these guys build for theirs, and you will be hooked.
/ Do I need a tractor?! #23
I'm of the opinion that everybody living anywhere needs a tractor with an FEL. Once you get one and your friends start calling, you'll know what I mean.
For clearing bush, I'd suggest a skid steer though...a pretty big one...and a construction backhoe. Rent or hire somebody. Use your tractor to clean up the mess after. Get a chainsaw and a splitter and you can likely sell the firewood for some extra cash too.
I can't imagine looking after horses without a decent tractor and FEL though. I can't imagine trying to look after ten acres without even if there are no horses.
You'll need a mower, some sort of tiller, and either a picket pounder or a post hole auger for fencing too.
Since you're mechanical and all this stuff costs money, I'd say you should buy used. Also, if you aren't already familiar with them, read up on hydraulics. In my experience that's what causes new tractor/equipment owners the most trouble.
/ Do I need a tractor?! #24
We have 10 acres and I started out with no clue or money what-so-ever. First I bought a 22" lawnmower for the 2acre yard.
It took me 6 hours to mow the yard, needless to say it only got mowed a few times the first Summer.
I still have that mower but it smokes a bit due to way too many hard hours.
Then I bought an ATV for hauling firewood and plowing snow. It was OK but I realized it was not the tool for the job when it took me 5 hours to clear out a bigger snow storm. I was worried that something on it wold break and them I'm out some real money.
I sold the ATV with 210 miles on the odometer and 104 hours on the clock.
Now I have a 30hp diesel tractor.
2hrs mowing time including setup and put away 72" rear finish mower, 60" snowblower makes easy work of cleaning up after any size snow 1.5 hours max. It hauls firewood, turns compost, pulls a trailer, moves anything that is between 10-1000 lbs and last but not least it entertains my son.
I really was convinced that I didn't need a tractor. After about three years I realized that it was the way to go.
I should have done that in the first place and so should you.
/ Do I need a tractor?! #25
Buy a tractor, buy a tractor, buy a tractor:laughing::laughing::thumbsup::thumbsup:
/ Do I need a tractor?! #27
20 years of horses and I never used a manure spreader. I have always had manure piles which were compost in a year which is sold in the spring for gardening. Horses are not real keen on eating where the defecate. Good pasture management means you have about an acre per horse and a way to rotate pastures. We have three different pastures on our nine acres with about 6 horses now. Some of the horses end up in the dry lot with no grass because of founder issues. Founder can be from stressed grasses, too much fresh high sugar grasses. With winters and next to no grass, summers with drought and toxic grass from the drought, you do need to manage your pastures. I drag harrow after horses have rotated off. Some of the smaller turnouts we go out and hand pick the manure. If you are not careful you end up with wormy horses that no amount of wormer is going to control if your pastures are a mess.
I have had no luck doing any real digging with a front end loader. Maybe I do not have enough weight in my backend even with a bush hog or pulverizer attached. I did move dirt with a box blade and a day, or maybe two days of driving back and forth. A big loader could have done the job in an hour. That barn was built in the middle of a pasture/filed with no surprise field stone or boulders and no stumps.
I have driven posts with a Shaver post driver. Dug holes with an auger. Dressed the gravel road with a blade. Dug out small stumps with what looks like a subsoiler. My little John Deere 870 is not a particularly good tool to remove stumps.
/ Do I need a tractor?! #28
I agree with all of this, people need to consider what is reasonable to expect from their property and their equipment. Most people who are new to all of this seem to over reach, too many animals before the new place is ready and equipment that is too small to get the job done. Country life is expensive.
/ Do I need a tractor?! #29
__________________
That it is. I have quite a few friends who have made that move to their dream place in the country, and they all seem pretty shocked. As one friend put it, "First it was the septic system in the winter, then the approach to the yard collapsed in the spring, and then summer came and I found out how much it all really cost."
I kind of lucked out with this place. We have a little less than an acre, city water and sewage, and we're 15 minutes from downtown. Having grown up with livestock I really don't want any, but there are several 5 and 10 acre lots around here so we get to see the horses and goats without having to look after them. I've also got those friends who moved out to the country, so when I get the urge I can always spend time helping them. In the meantime I've got enough room to run my business.
Still, if the right place came up for the right price out in the country, I'd likely buy it. Then there's that forty acres back home...I could always build a wood foundation and drop a house on top of it. when we retire.
/ Do I need a tractor?! #30
I now have the tractors I need to properly care for our properties, but for years used a pickup, ATV, then Ford Jubilee, BX2200 and then others.
I still don't have all I want; living in the country definitely is expensive, but worth every penny.
/ Do I need a tractor?! #31
You sound like a guy who will use a tractor of your own quite a bit, and take care of it and nurse it along, till you transform your place into something pretty special. Like stated, you will find a lot of chores that you will easily do quickly, and in no time the tractor will be easily seen as your best right hand. I've got a very nice 1952 8-N Ford that I can't do without around here. Good luck--and remember to look around awhile and get up to speed on prices a bit before you commit. There is always a real good deal for the guy who looks for one.
/ Do I need a tractor?! #32
Ok - we settled the question - one thing I didn't see being mentioned is to make sure you get at least full CAT 1 and working 3 point and PTO.
Plan on spending the winter nights reading here. Face it a tractor without implements is almost useless, you'll want things like bale spears, pallet forks, the list is endless. Some of the attachments will be pretty specific to the brand of tractor, but thankfully most are not. It is legal to put a John Deere tiller on a Kubota tractor.
Also - what are your trees like? Lumber prices right now are low, but you might have a lot of good beams standing there which only need a chain saw mill to coax them out.
You picked a good time to get in the market for a tractor. I'll also suggest that if at all possible get one big enough to carry a horse or a log.
good luck
/ Do I need a tractor?! #33
k
Legal yes.... A target for laughs and jokes..
Yes again...
Will work, yes again...
The value of the laughs you will get at the comments by some tbn members.... Beyond priceless!!!!!!!!!
/ Do I need a tractor?! #35
easygo said:
I really like that quote and could not agree more.
Yet another reason we all are members here and enjoy so many stories together!
/ Do I need a tractor?! #36
Do I need a tractor...
That's like walkin into a crackhouse and asking if you should get high. LOL
I just saw this thread...
Green, Blue or Red, buy one you will be happy. Old or new.
I have
2007 NH TC40DA
1955 JD 70 Diesel (wheatland)
1950 Allis Chalmers WD
1945 IH Farmall H
1940 JD A
BTW, did you know that ponies live well into their 40's and even sometimes 50's...
I have one almost 35 year old horse.
/ Do I need a tractor?! #37
Definatly get a diesel. I thought my Oliver 77 was the baddest tractor ever until I got my Long 560. Both are similiar in horsepower. But my ong feels more powerfull and pulls way better. In tug of war, my Long dragged that Oliver like it wasnt even there.
/ Do I need a tractor?! #38
As many have stated, living in the country is not cheap. We moved to 10 acres 4 years ago and started working on our small horse farm. 10 acres, 5 horses is a lot of work. Built 30' x 40' barn (build bigger if you can afford, you will not regret in the long run) for stalls and hay storage, then started on the pastures. Have 4 acres fenced into 2 pastures and small paddock. I have started cutting small pines (less that 6") for another 2 acres of pasture. My best tip for you is to get your pastures in shape before putting your horses on them. It will save you in the long run. Find you a good 30 hp tractor that will move round bails of hay. They are much cheaper to feed in the winter and during dry periods. I did not think 10 acres was much, but it's a lot to properly take care of. I drag my pastures a few times per month with a harrow or heavy piece of fence. Cleaning the stalls, I use the loader to move the poop to a pile behind the barn. Good luck.
Eddie
/ Do I need a tractor?! #39
ROPS = Roll Over Protection System = Roll Bar and seatbelt to keep you in the seat and protected in case the tractor goes belly up.
FEL = Front End Loader = Pretty obvious once you know.
3PT = Three point hitch = the system of three arms typically on the rear of the tractor for attaching implements. There are 3 "classes" Category 1, 2, 3, sometime referred to as CAT1, etc. This refers to the spacing and diameter of the pin holes on the 3PT arms and implements.
/ Do I need a tractor?! #40
I am also new to this forum and a new tractor owner. I also own 10 acres, but mine is flat and already mostly pasture.
First, I wouldn't buy a tractor without a FEL or diesel engine.
Second, you asked about reliability. If you go to the specific tractor sub forums on this site you will notice they are in order of number of members. My thoughts are that the most popular tractors are popular for a reason, they are good quality.
As a reference, I ended up with a 2003 Kioti CK20 with manual transmission, FEL, 5' BH, and 4' FM in very good condition for $5,000. So far I am happy with it.
As others have said, if I wanted to turn woods into pasture I would probably hire it out.
Good luck and don't forget to post pictures of your new tractor.
JMR 8ft Man Basket Skid Steer Attachment (A64553)
JMR 8ft Man Basket...
2025 IRANCH Tire Changing Machine (A64194)
2025 IRANCH Tire...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2001 FREIGHTLINER FL80 6X4 T/A VACUUM TRUCK (A67148)
2001 FREIGHTLINER...
2011 GENIE Z-45/25 TELESCOPIC BOOM LIFT (A65053)
2011 GENIE Z-45/25...
2013 Kia Rio Sedan (A64557)
2013 Kia Rio Sedan...
