Do I need 4wd and/or loader?
   / Do I need 4wd and/or loader?
Forgot to add one other thing:
I'm going to take about a $1100 trade-in hit trading out of the 2wd for a tractor I've only had about 4 months with 10 hours. Bad, huh? Hard lesson and waste of money. Almost makes me think twice about the whole trading thing at this point.
Maybe I should keep the tractor a while and try to sell on my own......I guess a loader added to the 2wd would increase the value as well so I wouldn't loose any money by adding the loader. Decisions, decisions....
thanks, jed
   / Do I need 4wd and/or loader? #32
Jed
Consider the following - address the amount of hours and the type of work you are doing now and in the future (dream work). The 2wd is a good tractor for basic farming not FEL work unless it is light duty work. I have a 2wd and a 4wd tractor both have loaders. I cannot push much with the 2wd loader tractor but it makes a good pushing downed brush and farming tractor. Consider your soil type - if it is south GA sand than if you envision only light duty loader work - just put the loader on your 2wd.
I use my heavier 4wd tractor loader for low hours heavy loader work. I use my 2wd tractor for general farm work. If you have alot of box blade scraping 4wd is best also.
Secret is to consider the hours. Also consider the plastic hoods on the John Deere tractors-don't push over trees with it. I have 2 all steel Mahindras and one older JD. If you need 4wd after you examine your needs, then sell the 2wd JD tractor outright- they have a great resale value.
Hope this helps.
Michelle
   / Do I need 4wd and/or loader? #33
Never heard a 2wd tractor couldn't handle a loader unless it wasn't designed for one.
I have 40 acres but I don't farm. No more than you can plow on 40 acres a 40-60 hp tractor with a loader would do anything you'll need done.
My 50 hp 2wd has a loader and I have no use for a 4wd tractor. A tractor without a loader would be usless for me.
Put a loader on your 2wd tractor and put it to work.
Jed
Hope this helps.
Michelle
Thanks Michelle....good advice. I don't really know what I'll actually use the loader for (with except to what I've said so far) yet. Pushing dead trees, moving hay bails around, pushing over small treess and bushes, dragging off stumps, moving heavy things around, who knows.....
Can't think of why I would want to move much dirt, but I'm new to this farming stuff. I'll probably keep the 2wd drive. The more I think about just throwing away $1100 the less I like it. ---- payment cheaper too.
thanks, jed
Also good advice......thanks, jed
   / Do I need 4wd and/or loader? #36
I too have 40 acres. I think a good guideline to follow if you are just going to use your tractor to do general maintenance, is match your hp to your acreage.. i.e. 40 acres, 40hp should suffice. That being said, when I bought my tractor, I came here for advice, and 99% of the feedback I got was get a loader, and get 4wd. I can't imagine life without either of those. Horsepower is useless unless you can put it to the ground. You can do alot of things to improve traction with a 2wd... tires, weight, etc.. but it in no way compares to 4wd. Also, like some others have said, when using the loader, the 4wd really shines... for example, pushing into a pile, you are applying alot of down force to the front wheels. If you are in 4wd they REALLY grab! That is just one example. Just my opinion.
   / Do I need 4wd and/or loader? #37
Don't be afraid of a few hours on a used tractor... bought mine with around 300 hrs on it and remaining warranty. Absolutely no problem...and buy in cost was less at the time...resale prices in your area may vary. All else being equal, local dealer and expertise is very useful.... have you looked around for a used, low hour, 4wd, loader JD tractor??
Yep, tough to move to different tractor from what you have..more $$ hurts.. perhaps you could borrow a 4wd/loader tractor from someone local for a short time to get personal experience on your place.
Fundamentally, tractor size and implements is realistically determined by the maximum you really need to do with a tractor (pulling power, FEL lift weight, etc) not the average/typical thing. If you target the average/typical, then much of the time you are fighting to get stuff done because you are underpowered or do not have the right attachment, or that extra hydraulic port, etc....
I fought thru several tractors (2wd, less hp than needed, no loader) and MADE them work, beat my body up, just didn't do some things, etc .... It is absolutely amazing how many more things I get done with MUCH less tear on my body now. Fundamentally, I moved from 35hp to 50 plus 4wd plus loader and matching equipment.
With 40 acres and part time, you will be astounded how diverse the tasks are you will seek to do....always more to do than you have time for...your tractor and attachments is the only time and work multiplier you can obtain. The pages of TBN are filled with the benefits of 4wd and usefulness of a loader. If you could step ahead 5 to 10 years and look back over the accomplishments with your current tractor versus a 4wd/loader tractor, the difference would be quite obvious. My boys frequently tell me, and rightly so, that I should have gotten my current tractor years and years ago.
So, all said and done, it's your $$ and only you know what else is tugging at your funds.....but if at all you can swing it, I'd hunt for a way to start out on your 40 acres with a tractor that has more power, function and features than you now think you need...you will DEFINITELY find ways to use all that and find a need for more.... almost everybody on TBN has had this experience, although some would argue the point.
You purchased the land to do things with it and shape it to match your dreams....the single tool most capable of making your vision come thru is your tractor and implements....matched with your vision and skill.
I wish you all the best, and continued contributions to TBN:thumbsup:
Thanks to everyone for the advice.....this site is full of very useful information of which I'm barely scratching the surface.
I'm going to do some more research while shopping and thinking, etc. ......I'm not sure what I need exactly but what I have now with harrow and plant my field. I probably won't trade because of the loss of money unless the deal is real good. The used 4wd is probably the only option at this time as far as a trade and I don't think Deere is going to come down anymore than $2000 off the regular price. Neighbor and best friend has 2 4wd Kubotas I can borrow so there is no rush.
One other option I'm thinking about is buying a used Ford 5600 2wd with loader for around $6500. Seems like a good tractor and I can probably get rid of it pretty easy. That will give me a taste of what I need. I will be looking at it closely on Friday. Got a farmer buddy who says he'll buy the Ford to use around his shop if I don't want it.....can't go wrong there.
Once again....thanks to everyone. I am very well informed now.
jed
   / Do I need 4wd and/or loader? #39
You're getting a lot of great advice and it sounds like you're listening to some very experienced people on the boards. The only mistake IMO you made when purchasing was not getting the loader....Oh well..... As someone said get the loader installed on your existing tractor and put it to work. If....after a few years you will know more about what your needs are and then either upgrade or pick up something to fill the need. That's pretty much what I'm doing. As I've said I have the 5103 with FEL and the 14.9x24 rear tires. So far I has done everything I've asked of it. If I was to do it over only two things I'd change. I'd have gone with more HP (only because I'd want it) and the wider 16.9x24 tires for better traction and less compaction. I'm in the process of moving to a larger piece of property myself (40ac) and it has a spring that runs through the center of the property. For the task of redirecting the water flow to allow more of the property to dry out I'll use either my boxblade and if that doesn't work I'll rent a backhoe for a week (although I want a bachoe of my own:) ).
Good luck.
   / Do I need 4wd and/or loader? #40
Getting a tractor with 300 hours is something like getting a used car with only 20,000 miles on it.
There was an old thread here about this; it kind of listed out the equivalent of hours in what would be miles on a car/pickup.
EDIT: This thread had some infor about hours. Not the one I was looking for, but on subject
http://www.tractorbynet.com/forums/buying-pricing-comparisons/24055-hours.html
2015 Ford Transit Connect Passenger Van (A59230)
2015 Ford Transit...
50 Foot Loading Dock (A56436)
50 Foot Loading...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
1605 (A57192)
1605 (A57192)
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2018 KENWORTH T680...
