DK45SE hst range selector
/ DK45SE hst range selector #1
airlynch
Meatloaf Mtn WI
Kioti DK45SE HST
My tractor has 240hrs and would only work in M range or N. Today it stopped grabbing M and is in neutral even when dash shows H-M-L-N based on selector (i.e shifter).
I have a service manual on the way, but would welcome any guidance you all may share.
/ DK45SE hst range selector #3
Possible that stupid spring pin in the lever connection thing, there's 2 pins in it, a smaller dia one goes into the larger one, tack weld it in place 😉, that's my next move.
I think the pin may have just sheared from selector to shaft.
Parts diagram shows two spring pins ...I want to just put a nail through it. :)
Thanks all.
Bloodyrun where would you place a weld?
/ DK45SE hst range selector #6
First inspect for a missing or broken spring pin were the range lever connects to the shaft that comes out of the tractor , put another pin back in then I would tack weld it at the end of the shift and range lever on the flush part , this will keep all the slop out of everything, if for some reason you would ever need to remove the lever just grind the weld off. This is a quick way to band aid the problem, probably not the correct way but should work.
/ DK45SE hst range selector #7
I had this problem with mine and ran a stainless wire thru the pin to keep it in place. Most recently I found that the pin had gotten loose in the shaft. I removed the assembly and drilled the holes out to 1/4" and installed a new 1/4" pin. The old pin was metric. Now my shifter has no more slop in it.
Thanks all. Much appreciated. I am back up and running.
/ DK45SE hst range selector #9
how hard was the range selector to remove? I should really do the drill out the hole for a pin thing instead of tack welding it on the end BUT it's soooo much quicker 🤪
/ DK45SE hst range selector #10
It would be much easier if you remove the rear tire for easier access. You do need to remove the shift lever knobs and plastic shifter housing/fuse box cover. Four bolts on the shifter bracket and one link to remove.
/ DK45SE hst range selector #11
Any YouTube on removing it?
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2011 Kenworth T800 Truck T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2011 Kenworth T800...
2014 RETESA 210BBL CRUDE TRAILER W/ PUMP (A65643)
2014 RETESA 210BBL...
2022 CATERPILLAR 259D3 SKID STEER (A65053)
2022 CATERPILLAR...
6' Bush Hog (A62613)
