DK45SC Starting problems
/ DK45SC Starting problems #21
Thanks for the suggestions and speculations. My 2006 DK45 has the lever by the solenoid...I always wondered what it was for! I have a few things to try out. The past few times I've started the tractor, I've pumped the plunger on top of the fuel filter 8 or 10 times and the engine started on the first try (this may or may not be related, given how intermittent the issue has been in the past.
Finally, jimglassford, is your fuel tank below the engine, then? Mine is on top of the engine just forward of the firewall.
As others have pointed out, the engine stop mechanisms could be causing the issue but since you can use the priming system to help start the tractor, I would think you have a fuel issue outside of the fuel injection pump.
My tanks are under the platform and thus requires a lift pump to bring the fuel up to the engine. I believe I have solved my starting issue this week. I purchased my DK55 tractor used and the previous owner, a landscape supply yard, had a real bad diesel mechanic. My tractor showed the same symptoms as your DX45SC. Whether the tractor was cold or warm, I had to crank it a long time to get it to start. If I pumped the primer a number of times, it would start immediately. I had to pump the primer until I heard the fuel return to the fuel tank. This pointed to the fuel delivery system. I took the lift pump off of the tractor, disassembled the unit and wiped down the diaphragm, valves and internal body. I then checked all hoses for cracks at the ends where they fit over the metal nipples at the pump and filter. I replaced the adjustable hose clamps with actual spring fuel line clamps. I am not a big fan of adjustable hose clamps on small diameter hoses, they distort the hose as it clamps.
Over the past few days, I have tried starting the tractor when it is cold and when the tractor is warm, after shutting down and sitting for 20 to 30 minutes. It now starts each time. I believe the issue was that when the tractor was sitting, the fuel slowly drained out of the lift pump.
The DK45SC does have the fuel tank mounted in the bonnet. However, there is a fuel lift pump (item 19 in the diagram). I was trying to find a diagram of the fuel tank to see if the DK45SC fuel tank pulls fuel out of the top or bottom of the tank. Since you can pump the primer and then the tractor starts, you may have a fuel leak or an air leak that is removing the fuel from the fuel line. Cranking the engine for a while allows the lift pump to refill the system that feeds the fuel injection pump.
There is still the possibility of a shut off system issue. You have the integrated fuel shutoff solenoid and an external cable operated shutoff. Make sure the cable pull shut off is fully forward when you try to start the tractor. There is also the possibility that the integrated solenoid is getting hydraulically locked if oil is getting into the solenoid. However, your analysis of pumping the primer a number of times then the tractor starts still points to a fuel system leak emptying the fuel line.
/ DK45SC Starting problems #22
My DK45SC has the tank in the bonnet, the bottom of the tank is above the engine driven fuel pump (not sure I would describe it as a lift pump) The fuel tank outlet is at the bottom of the tank, and the fuel line runs downhill to the pump; Any leaks between the tank and the pump would have fuel leak out (not air leaking in). From the pump, the line does run uphill to the fuel filter, but even the top of the filter is below all but the bottom 1/4 of the tank. As long as you have at least 1/2 tank, I do not know how you could get an air bubble in my particular setup. Also, the 'plunger' that sits on top of (my) fuel filter is not a primer pump (per se); it is an air bleed.
/ DK45SC Starting problems #23
My Also, the 'plunger' that sits on top of (my) fuel filter is not a primer pump (per se); it is an air bleed.
According to the parts diagrams, you should have the following assembly as a fuel filter. The spring loaded plunger on top is a primer to move fuel through the system. The air bleeder is on the side of the casting.
/ DK45SC Starting problems #24
On some primer pumps it was required that the pump handle be pushed down and turned a quarter turn to lock it down,
otherwise it could allow air to be sucked in.
One other thought if you have a screen in the outlet of the tank and it is getting restricted you could suck air into the system from any joint.
My fuel filter unit looks exactly like the one jimglassford posted. I think the pump on the top helps bleed air out when the air bleed gadget is open, but primes when it is closed. My fuel supply system is pretty much all lower than the fuel tank, so any leaks shouldn't let air into the system...I don't see a mess of fuel leakage anywhere, either. Can relays and solenoids misbehave intermittently? Since the tractor runs well once I get it started, I don't think fuel contamination or plugged filters will be the problem. A glitchy relay or solenoid could act like this, though. I hate the way Kioti seemed to relocated relays from year to year; it is hard to trace wires to the correct relay!
Bob
Also, I have never yet had the tractor start at the end of a long crank; it either starts right up, or not at all. It may take a few tries, with filter priming in between to get it to fire, but when it does start it is right away after the key is turned to engage the starter...I don't know if this is relevant, but that has been my experience...and, again, I don't know if the priming is relevant either, maybe the tractor just wants a certain number of tries before it is willing to go!
/ DK45SC Starting problems #27
If the fuel flow is restricted some where any place after the restriction can leak air in and not show a fuel leak.
The injection pump will pull a vacuum once running.
/ DK45SC Starting problems #28
After the end of a "long crank" do you leave the ign switch on the "run" position; or do you turn the ign switch "off"?
Although I asked it before (post 15), and you have never answered, I am forced to ASSume you are turning it "off" between crankings, which will "reset" the "stop solenoid timing relay" / which leaves only the "solenoid timing relay", the "solenoid relay", or the "fuel solenoid" as being your culprit. Of those 3 things, the "solenoid relay" is BY FAR the most likely.
If you can confirm that you do turn the switch off between crankings (and if you want me to),,, I can (try) to explain how to narrow down which of those 3 are bad, using a test light, or a VOM
Kioti Paul, ordinarily I would turn the ign all the way off before starting another cranking round. However, after you suggested it, I tried it both ways and didn't see any difference.
In any case, tonight things went from bad to worse! Without any priming or anything, the tractor started right up, however when I started to drive off, the tractor faded and died. When I went to restart it, it fired right up then went full throttle (scary!!). Shutting off and removing the key made no difference, so I went out to use the rack lever next to the solenoid...the rack lever wouldn't budge! Finally, I managed to get a fuel line off and the engine starved.
Whatever the original starting problem may have been caused by, I think I definitely now have a "shop" issue way, way beyond my competence to tackle.
Thanks to all for the hypotheses and suggestions.
/ DK45SC Starting problems #30
It sounds like you have the common Kioti Injection Pump Failure. DO a forum search before you take it in. The Kioti Dealer can only replace the pump and that is huge money.
/ DK45SC Starting problems #31
Ouch! jimglassford is right! There is a 'sticky thread' at the top of the forum describing this problem.
It happened to me several years ago, after stopping and eating lunch, I came out and started my tractor, and it went immediately to what seemed like full throttle, neither the governor or the throttle (or the ign switch) had any effect on the "run away".
Turns out to be the gear teeth on the injector pump 'pistons' (sleeves) breaking off, and jamming. It always seems to 'stick' at or near full throttle!
I had very little experience working on diesels, but there is an outstanding tutorial (somewhere in this forum) on how to do it.
I purchased all 4 'sleeves' from H&H Diesel Service, in Milton, WA - delivered to my door for $52. Really nice people! As I recall, all I needed from Kioti was a few gaskets. I got 'out' for less than $100 (& a couple weekend's work)
I was pretty intimidated by the job, so I REALLY understand taking it to a shop. Incidentally, at the time Kioti would only replace the injector pump with a new one $1,500 in parts (+ labor). You might check with a diesel repair shop in your area to see if they repair the injector pumps - probably could save a good bit of money.
Lastly, not to be a wet blanket (and it is quite a coincidence) but I'm guessing this is probably not your original problem. I still bet, after repairing the injector pump, your old nemesis will be back.
Good Luck!
I had the classic injector pump issue already with this tractor at 600 or 700 hrs, but it stuck at "won't run" rather than "full throttle". I now have over 1500 hrs. The first time this happened, my mechanic came and did the tear-down in my driveway (I have no barn, shop or garage) while I "helped" by passing him tools. It isn't something I want to undertake again, especially in the fall...plus my mechanic (the guy I originally bought the tractor from) died last spring and it is nearly impossible to get anybody else to do that sort of unsheltered, onsite work. So, I'm going to trailer it in to the current Kioti dealer here and do my best to convince them to have it rebuilt rather than installing a replacement unit.
One way or another, this is going to cost me...
Thanks, again...this forum has some great folks.
/ DK45SC Starting problems #33
Ohhh, bummer! Mine broke around 500 hrs, now I have 1,200 hrs. Looks like I may be having a 'relapse' shortly. Yikes!!
/ DK45SC Starting problems #34
If you decided to work on the injection pump yourself, or have a third party work on the injection pump, Take a lot of pictures and share them with the forum. We all keep learning.
Working on it myself would only be marginally superior to turning a chimp loose on it! My mechanical competence is minimal, and my lack of confidence in the outcome of any mechanical repair task I undertake is well-justified. On the other hand, on those rare occasions where I undertake a repair and it actually works, it yields an extraordinarily satisfying sense of accomplishment. Since I don't have a backup tractor to see me through, I'm not in a position to take a risk of a botched job leaving me tractorless for a long period...the horses get hungry without their round bales.
It looks like the local Kioti dealer has no qualms about having the injector pump rebuilt, so that should lower the cost a bit.
Thanks, again, for all the encouragement.
/ DK45SC Starting problems #36
One option you could consider would be removing it and sending it to be repaired.
There is a member here "the pump guy" that does rebuilding if you contacted him he could give you a price.
Might be nice to have another price in your head when talking to your dealer.
Also you could contact your loacal diesel shops to see how they compare.
I now see that your pump may not unbolt like the ones that I am used to,
the link is to an interesting article on Kioti pumps;
IP Removal
/ DK45SC Starting problems #37
The Injection Pump on the DK45SC unbolts like any of the others. It is the same design. A new IP will cost $1,400 for the part alone. It is very easy to unbolt and send in. I did the same with my DK55 when I thought it was the issue. It cost me $550 for an evaluation and new seals. The fuel injection repair place found nothing wrong with the IP.
I've had my tractor back for a few days and it seems to be working great again. I hope this will be a permanent fix this time.
My wife got tired of worrying about down-time, so she bought a used Kubota 2650 as a back-up unit. I'm hoping she'll find her new tractor easy enough to operate that she'll take over more of the horse chores (hah!).
/ DK45SC Starting problems #39
What was the diagnosis and the total bill?
/ DK45SC Starting problems #40
Thanks everyone for sharing here. I have a DK45S engine model 4A220 LWB serial number HD7300273 that I am experiencing the same symptoms of the OP. Hopefully it doesn't turn out to be my injection pump!
Peanut Wagon (A64127)
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
2009 Ford LCF Box Truck (A66285)
2009 Ford LCF Box...
John Deere 2032R Loader Tractor (A66285)
John Deere 2032R...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
(2) Firestone 18.4-16.1 Tires w/Rims (A64127)
(2) Firestone...
