rd_macgregor
Veteran Member
- Joined
- May 14, 2008
- Messages
- 1,875
- Location
- Prince Edward Island, Canada
- Tractor
- Kioti DK45SC, Kubota B2650
Last winter my 2006 DK45SC with about 1500 hrs started to get stubborn about starting. It had always before started immediately on cranking, so this was an unpleasant surprise. I thought it might be old/weak glow plugs, since using the block heater seemed to help. The problem went away on its own last spring...until a couple of weeks ago, when the same thing started (or not!!) again. Now, this is still fairly warm weather so I doubt the issue is the glow plugs. It will crank over enthusiastically, but doesn't even cough or sputter. Then, after a few tries, it sometimes will fire right up....and run great as long as I don't shut it off. I figure something, somewhere in the fuel delivery system (fuel, pump, filter, lines...) is goofy, but don't know where to start, or what is the best fit for the symptoms.
I welcome suggestions that might point me in the right direction.
Thanks.
Thanks.
