DK45 CAB - A/C issue
   / DK45 CAB - A/C issue #1
highboard
DK45S
Just got a DK45Cab, had A/C compressor replaced after only 6 hours (squealing). put another 40 hours on & now again it squeals really bad upon start-up. Anyone else having this problem?
for some reason it takes about 5 - 10 minutes of engine "warm-up" before I can turn the A/C on without it squealing. THis is of great concern since I mow a 60 mile trail in the middle of nowhere and would hate to get stranded in 90+ deg weather.
   / DK45 CAB - A/C issue #2
Is it the compressor locking up, or just the belt loose?
   / DK45 CAB - A/C issue #3
I have the 45 cab (85 hrs), as of yet no problems with the AC. I start the tractor and let it warm up a bit and then turn on the AC, you can hear it pull the motor rpm's down but no squealing from the compressor. Yesterday I was mowing in 90 plus heat, had it cranked up and was comfortable but not freezing. I am fussy about keeping the radiator fins clean and the screens clear, after two hours of mowing I blow out the radiator with an air compressor. I also take off the side panels on the tractor, when left on those panels get so hot you can't touch them.
belts are adjusted correctly, the compressor just locks up & belt slips on compressor pulley. so far it seems ok as long as I let the tractor warm up for about 5 minutes then start A/C. but having gone through 1 compressor already, it sure makes me nervous about mowing the 60 mile trail, because I CANNOT run this tractor without A/C in 90+ weather for 12 hours - would be like an oven.
anyone know what changes occur after 5 minutes (warm-up) that would then allow the AC to run without belt slipping?
   / DK45 CAB - A/C issue #5
I know you said the belt is adjusted correctly, but are you sure? I had this happen on a DK65s cab, customer thought the compressor was going out, said he adjusted the belt. When we got it in all we had to do was tighten the belt and all was fine.
Are you sure you are not just seeing the compressor clutch engage and that is what you think is locking up?
When we start and run our tractors around on the lot the A/C is on from the get go.... pretty much like my truck.
The only reason I can think the belt doesn't slip after 5 min is that the belt has warmed up and is less likely to slip on the clutch. I would say tighten it up a tad bit more and see what happens.
   / DK45 CAB - A/C issue #6
I have had my A/C belt scream a few times also. This afternoon I checked the belt and found it to be loose. I tightened it up. Simple job. I think it was just belt stretch. Common for a new belt.
No more scream on start up.
   / DK45 CAB - A/C issue #7
highboard
I had never considered a cab or AC but as HOT as it has been this summer, it may have been a wise choice. Hope everything works out with your AC problem.
   / DK45 CAB - A/C issue #8
I had the same problem on my DK65SC shortly after I got it. I checked the belt, and it felt tight. Then I tried belt dressing. It helped, but I still got squeeling after start-up. Mine also quit after a few minutes. I finally decided to tighten the belt more before I called the dealer. That cured the problem. I have put about 25 hours on it since tightening the belt without a repeat, and that air conditioner gets a work-out down here. I asked the service tech about it when he came out to do the 50 hr. service, and he told me that he was sure it was the belt.
   / DK45 CAB - A/C issue #9
I had the same thing occur on my new dk55c. At ten or so hours the air caused the noise and the snugging up of the new belt fixed it. %0 hrs now and no repeat. I suspect a new belt stretch is a bit the norm.
rick
   / DK45 CAB - A/C issue #10
I don't think what you are describing is unique to Kioti at all. As the others have said, sometimes a belt that seems tight starts slipping in the heat. It apparently doesn't take much slipping to cause a loss in output. Good luck.
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
1965 Rogers Low Boy Trailer (A57453)
1965 Rogers Low...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
ADS Bulk Seed Buggy (A59814)
ADS Bulk Seed...
6ft Wolverine Sweeper (A57454)
6ft Wolverine...
