DK40SE Squeal When Moving in Reverse.
/ DK40SE Squeal When Moving in Reverse. #261
Sounds like the beast! :thumbsup:
I like the new use for an oriental rug! :D
I'm still waiting for an hydraulic fitting from the Surplus Center so I can get reading at the test port.
/ DK40SE Squeal When Moving in Reverse. #263
That danged squeal sure is a racket, isn't it?
Kinda taints the wonderful feeling of a new tractor.
Yes, I recycled an old faux oriental rug that was too shabby for home use into a garage floor surface. It's not cold to lie on in the winter, I can see if something is leaking, easy to sweep off, doesn't matter if it gets diesel/hyd fluid/oil spots on it, and when it gets too tatty it's off to the dump.
I figured having another available audio/vid of the squeal might help others who wonder if the have "it".
The more videos posted the less it appears the issue is isolated to 1 or 2 tractors and more difficult it is for Kioti to argue it is. Thanks for spending the time to create and post the videos.
/ DK40SE Squeal When Moving in Reverse. #265
Well guys i think i got one of the squealers. I just watched the video here n mine does that same thing. If i rememberr correctly you all said as now kioti hasnt came up with a fix, correct? Should i just make,my dealer aware of it. Thanks
Sorry, mine is a DK50 hst was a demo with 42hrs when i bought in early spring. Now have 80 hrs.
Well it been over a year since I first reported this issue to Kioti and over 3 month since I received any information from their customer support department. So it appears Kioti is leaving it to their customers to troubleshoot.
The following is the Charge Relief Pressure reading from the reverse and forward test ports.
The transmission range selector is in neutral for all tests.
The following reading occur after the reverse and then forward HST petals are pressed and released. Reverse petal press 1st and then the forward petal 2nd and then released.
Reverse Test Port
Engine RPM ......PSI
1000.....155
1500.....180
2000.....190
2500.....195
2800.....200
Forward Test Port
1000.....155
1500.....180
2000.....190
2500.....195
2800.....200
The following reading occur when the forward and then reverse HST petals are pressed and released. Forward petal press 1st and then the reverse petal 2nd and then released.
Reverse Test Port
1000.....160
1500.....180
2000.....380
2500.....390
2800.....360
Note: it appears when the release petal is released the HST does not return to neutral position. Checked twice.
Forward Test Port
1000.....155
1500.....180
2000.....190
2500.....195
2800.....200
After the tractor is hot, used continuously for more then 2 hours, the reading when the reverse and then forward HST petals are pressed and released.
Both forward and reverse ports:
1000.....170
1500.....190
2000.....200
2500.....200
2800.....200
The charge relief pressure for both forward and reverse test port never reaches the recommended pressure of 255 psi when the HST is truly in neutral position and under no load. :mad: Kioti and the Dealer said they tested this last year!
It would be a great help if someone with a DK Tractor with HST transmission that does not have the problem could get pressure reading at the HST Pre-charge Port. Between the HST Pre-charge In-Port and the HST filter.
I wondering if the HST Pre-charge Port Pressure should be in the 300 psi range instead of the upper 200 psi range as my previous test shown. To put it a different way, if the HST Pre-charge port pressure was higher would I get higher forward and reverse charge relief pressures? My concern with this theory is the HST Pre-charge Port Pressure reading I took earlier were linear but the test port reading are non-linear. Meaning the test port pressure top out at 200 psi before the engine reaches top RPMs when warmed up. But the HST Pre-charge port pressures continue to increase with engine RPMs.
/ DK40SE Squeal When Moving in Reverse. #267
I am new to posting, but have been a thread stalker for a long time. I bought a new Kioti DK40se hst (no cab) about three weeks ago (ordered not off the lot) even after seeing this thread, hoping that Kioti would have the squeal problem fixed in production by now. I regret to tell you that they don't and mine squeals as bad as the others have described. My question is how many with this problem have tried the fix tnewbern came up with and have been successful in eliminating the noise. I am going to order the parts to make this swap and hopefully eliminate the squeal.
I know I am complaining, but don稚 get the wrong impression, I like everything about this tractor and everything else seem to work good and be well built. I have had and still have a few tractors and the Kioti is the easiest to drive and operate out of all of them.
/ DK40SE Squeal When Moving in Reverse. #268
well i actually got Kioti to tell my salesman that the issue is in the tube that has been discussed here. Its due to harmonic noise from the solid tube, and they insist that it will not cause a problem, and the rubber hose kit will stop the noise. My salesman has ordered the repair parts from Kioti, and he'll drop by and fix it when the parts arrive. We apparently don't have as much of an issue with it in the colder climates as they do in the warmer states. And mine ONLY squeals when its real hot outside. Time will tell if this fixes my problem.... But my Stereo and a/c does block out the noise.
My question to Tnewburn is if the hose eliminates the noise, why not just use the hose and forget about the metal tube??? Am i missing something?
/ DK40SE Squeal When Moving in Reverse. #269
Guys, after reading this I'm considering buying a shuttle shift manual gearbox rather than chance a long-term problem as described here. Everyone who owns HST with a loader speaks highly of them, but I'm really afraid of spending what to me is a huge chunk of money on a headache. If you could do it again, would you forgo the HST for a shuttle shift?
Thanks,
Mike
/ DK40SE Squeal When Moving in Reverse. #270
@ Mike (southerniltractor)
I've got 140+ hours on my DK40 HST, 2010 model, and no problems like this. I really think it is a hit and miss issue. If you really want the HST, talk to the dealer and have them let you use it for a day to make sure the noise doesn't start and just make sure they are prepared to address the problem "if" it should happen?? I really think if you run it for a day around your property, you should be able to figure out if it has it or not???
IMHO, if you plan to do a lot of loader work, you'll want the HST for sure, especially if you'll be doing any precision work (again, IMHO).:D
Mine has been an excellent performer. I do envy the cab owners though!!! More importantly, I do hope Kioti is taking notice of this and trying to find a solution and take care of its customers!!!!???? If they do find it, they need to get the fix out and get their customers taken care of ASAP......think of the goodwill that could create for the owners and potential buyers......dang, I should work for Kioti, shouldn't I??? I'm thinking I should work as a Quality Specialist/Customer Service Rep.....wonder if they have any positions like that??:laughing::drool:
Sorry! Ventured into lala land......good luck on your purchase and to all who are dealing w/ this issue!!!:)
/ DK40SE Squeal When Moving in Reverse. #271
I've put 124 hrs on my 2011 DK35 HST since receiving it at the end of March. My experience is similar to grsthegreat. It will sometimes squeal in reverse when it has been used for an hour or so in hot weather. Even then the squeal is sporadic.
My previous tractor was a geared model. The HST is much easier to operate and useful for my needs. As gkh7890 says, it is better for precision work. It is much less scarey working close to buildings, on hills, etc. I now mow the lawn with the tractor and 6' finishing mower instead of the old riding mower.
I think an HST is safer for most of us casual users with small acreages. I would not want to go back to a geared tractor, squeal or no squeal.
/ DK40SE Squeal When Moving in Reverse. #272
Squeal or not, going to shuttle shift to avoid the 'possibility' of the squeal is IMHO ridiculous. Get what you want or need as far as a transmission choice, but don't base your decision on this thread's discussion exclusively. Those of us who have the squeal issue in our HST's are few and far between in the overall number of tractors out there that are in use and our sole objective is to solve the problem by comparing notes, ideas and possible solutions in addition to keeping Kioti owner's aware of a potential problem in some Kioti tractors with HST.
/ DK40SE Squeal When Moving in Reverse. #273
I will not have my flexible hose till next weekend to try, but after reading back through the thread I am wondering why a faulty hydraulic pump could not be the culprit. The reason I bring this up is my dad (a long time tractor mechanic) and I were able to reproduce the noise while it was moving very slowly in reverse allowing us to walk around the tractor to pin point the noise. The point being that the source of the noise is directly behind the right side loader bracket, right where the end of the hydraulic pump is located.
Has anyone else been able to locate the source of noise on their tractor and if so is this what you are finding? Has anyone taken pressure readings right out of the hydraulic pump to see if it is low after the tractor is warmed up? Not sure, but just seems like I should be concentrating my efforts at the source of the noise.
Sorry to heard Kioti still selling tractors with the issue.
The flexible hose fix will reduce or eliminate the noise but I primary concern now is the low pressure at the test ports as noted in previous posting. I cant help but wonder what this is doing to the HST.
Note: my hydraulic pump was replaced last year around August, it did not fix the issue. This was the first thing the dealer and Kioti attempted because there was a known issue with low pressure from some pumps. It would not hurt to check the pressure at the pump.
I'm wonder if replacing both the hard line going into the HST filter and the short hard line from the HST filter to the HST pre-charge port would boost the pressure enough to get the correct pressure at the charge relief test ports? While I would like to test this I'm not too hopefully based on my past pressure reading. Increasing the engine RPM will increase the pressure at the pre-charge port somewhat linear but the charge relief test port pressure reading are non-linear and seem to top out at 200 psi. If I remember correctly pressure should be around 255 psi. Unfortunately due to my schedule it will be at 3 weeks before I can test this.
/ DK40SE Squeal When Moving in Reverse. #276
Kattywumpus, this is good information. I was not aware of any hydraulic pump issues. Did it seem like the source of your squeal was also coming from the pump?
I should probably check the pressures just in case it would happen to be the pump even though it seems to be the same as everyone else痴 squeal. Do you know what the out put pressures of the pump are and where to check them?
I also thought about replacing the other line if replacing the short steel line does not fix the problem. I would guess there are similar restrictions in that line and by replacing it should help boost your pressures.
/ DK40SE Squeal When Moving in Reverse. #277
Another victim. DK45 HST. I have 5 hours on my tractor and I hear the whine...its not a squeal per say on my tractor but more a whine just like Robifield's video. It happens every time you go to reverse once the tractor is up to running temps. Any offical word from Kioti yet? I hope they get this fixed. I saw this post before buying and decided to try it anyway. I let the 4K offer expire while I debated. Even told my dealer about my concerns and sent him this thread and he sid he'd sold 15 of these tractors with no problems. Guess I'll have the honor of being first with the problem.
/ DK40SE Squeal When Moving in Reverse. #278
No word yet from my selling dealer, but as you posted I just was writing myself a note to contact Bob at MIE about what if anything he has heard from Kioti. I spoke wih him at length a few months ago and have been away since then.
My dealer says he is hearing nothing new and talks about how many zone reps Kioti has and how they are switching around their territories, etc.
I asked him this past week if I should write a letter direct to Kioti about this - (while expressing my concern about him not getting caught in the middle with them). He said he'd hear from them no matter what if I write or call Kioti directly. I told him I cannot let this fade into off warranty time by inattention or intent on Kioti's part.
Yes this problem needs to be addressed- not ignored into oblivion by Kioti. They built it, they sell it, they make the profit, they need to step up and resolve this issue.
Kioti says they do not pay attention to web sites like TBN, but has anyone noticed the add banners for Kioti on both the Kioti owning/operating and buying forums here at TBN ? Evidently they pay attention to advertising here, and now they're pushing the Mechron at all of us; including special pricing offers to existing Kioti owners. I can say with out a doubt I will NOT be buying another Kioti ANYTHING until this situation is resolved. I'd rather see them investing in fixing this problem than in selling us or anyone more of their products.
Has anyone heard anything as to progress on this issue from their dealer or Kioti reps?
/ DK40SE Squeal When Moving in Reverse. #279
Well, I finally go the chance to try my tractor (DK40 HST) with the flexible hose (exact same setup that tnewbern speced out a while back on this thread) installed and I hear no squeal. I do have to caution that this is only after two hours of use, but my squeal would start within the first 5-10 minutes before. I am very happy about the result, but I hope that this is the fix and not just a bandaid for another problem.
RJJR I know how you feel. I went through the exact same scenario and my tractor started squealing at 3 hours and now has 22 hours. It seems suspicious that all of us are the first ones to have the squeal even though there are so many of us.
I want to thank all of you on this thread that have suffered with this problem for many hours and have done countless hours of testing to diagnose this issue. Kattywumpus, tnewbern, coyote machine to name a few for staying with this and keeping us all informed so we would not have to suffer as long as they have. Hopefully Kioti will step up with there findings on this issue too. Thanks Guys!
/ DK40SE Squeal When Moving in Reverse. #280
I've been having a similar problem with my Ford New Holland 1520 hydrostatic motor squealing, but I also have a loss of pressure after the charge pump when driving in either forwards or reverse.
http://www.tractorbynet.com/forums/hydraulics/173127-tractor-squeals-under-load-after-8.html#post2522394
Does the squeal you guys are talking about with your Kioti tractors actually cause low pressure, or is it just a noise with no loss of power? It sounds like some of you are losing pressure, but the dealer is saying it's just a harmonic oscillation that won't cause any power issues?
Thanks,
Luke
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
445 (A63290)
445 (A63290)
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
2022 CATERPILLAR 914 WHEEL LOADER (A65053)
2022 CATERPILLAR...
Transfer tank (A61567)
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
