DK40SE having problems starting
/ DK40SE having problems starting
Got the part in the mail today. It took literally 15 minutes for me to change it out, however I must not have correctly lined up the plastic moulded retainer clips that hold the clamshell pieces together after the screws are removed as suggested by K0ua. It is not tightly put together at the bottom. I will try it again tomorrow as it started to get dark.
There was no visual corrosion or any signs of water damage. I think the part was just bad. The new one works great. I can't tell it if is the old style or new one some of you have spoke of. It does not close when I pull the key out so it might be the older style.
THANK YOU EVERYONE FOR YOUR HELP!
/ DK40SE having problems starting #24
I have heard the new one closes. If yours don't tell your dealer you want the cover for it.
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A64553)
2018 Takeuchi...
2010 CATERPILLAR 120M AWD MOTORGRADER (A63276)
2010 CATERPILLAR...
2008 Chevy Trail Blazer (A62679)
2008 Chevy Trail...
2017 FREIGHTLINER M2 WATER TRUCK (A65643)
2017 FREIGHTLINER...
2004 Mack CH613 Concrete/ Water Mixer Truck (A64194)
2004 Mack CH613...
2019 Mercedes-Benz Sprinter Box 1500/2500 Van, VIN # WD4PE7ED3KT012316 (A65563)
2019 Mercedes-Benz...
