DK40SE having problems starting
/ DK40SE having problems starting
Got the part in the mail today. It took literally 15 minutes for me to change it out, however I must not have correctly lined up the plastic moulded retainer clips that hold the clamshell pieces together after the screws are removed as suggested by K0ua. It is not tightly put together at the bottom. I will try it again tomorrow as it started to get dark.
There was no visual corrosion or any signs of water damage. I think the part was just bad. The new one works great. I can't tell it if is the old style or new one some of you have spoke of. It does not close when I pull the key out so it might be the older style.
THANK YOU EVERYONE FOR YOUR HELP!
/ DK40SE having problems starting #24
I have heard the new one closes. If yours don't tell your dealer you want the cover for it.
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2016 Ford F-150...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
John Deere 5000-Series Tractor Grill Guard (A65640)
John Deere...
FECON CEM36EXC2-FS-XXV-0LPK11 DRUM MULCHER (A64277)
FECON...
