dk40 front end
/ dk40 front end #1
ualjack
Granby CT.
DK40
Hi, I'm new to this site, I have a dk40 and the front end ring gear has blown apart for the 2nd time, and was wondering if anyone else has had this problem? the dealer tells me I am the only one they know of to have this problem. the last time I was picking up a load and the front tires were off the ground up in the air when I heard the gear blow apart. the wheels were no where near the ground in the front when it happened. /forums/images/graemlins/confused.gif
/ dk40 front end #2
Why would the front tires be off the ground when picking up a load? Never heard of any problems with the front diff. Why would you have the front end up in the air while using the loader? I don't understand what exactly you were doing with the tractor when your problem happened.
/ dk40 front end #3
I'm sorry to hear you're having a problem. I'm having a bit of a time grasping this though. You say it "blew" apart while up in the air?
I don't quite see how that could even happen, but I'm sure something did.
What were you doing the first time that happened?
I've heard of a couple of problems with a broken gear on a DK55, and some of the first DK45s had some problems but they changed the gears on those a while back. I haven't heard anything about any on the DK40s.
I'd kinda like to know why the front wheels were in the air though. If you're doing that a lot, and letting them come down hard, you've been stressing everything in the front end.
Most Kioti users that I know work their tractors pretty hard, but there are limits as to how much and what type of abuse any tractor can take!
You said that the last time you were picking up a load... Do you mean with the loader, or a backhoe?
John
/ dk40 front end #4
He could be picking up something heavy with the 3 point letting the front end come up, and then slam down. /forums/images/graemlins/tongue.gif
RedDog
/ dk40 front end
I was driving forward, cutting into a bank with the front loader, cutting up a banked hill from a flat surface. the front tires were about a foot off the ground when it broke. when I heard it pop I backed down, dropped the load and checked the shear pin. which is supposed to break before the ring gear. it was broken. but, I brought it into the dealer because I didn't like the sound in the front end. the shear pin should have left everything free in the front end, but I could hear something binding and catching as I rolled forward. I agree if I had slammed it to the ground at full power it would have done some damage. but that was not the case. but even if it was, again that is what a shear pin is supposed to do take the shear force before damage occurs. I think I was cutting into a hill the first time this happened too. My father-in Law has a 30hp kubota and does the same work around his place and says it should'nt be a problem. he was impressed by the kioti's power though.
/ dk40 front end #6
Is it possible that the bucket is moving rearward and contacting the front tires?That could force them to both turn against the drivetrain rotation without the benefit of differential action.......just throwing it out there,Mike.
/ dk40 front end #8
</font><font color="blue" class="small">( I was driving forward, cutting into a bank with the front loader, cutting up a banked hill from a flat surface. the front tires were about a foot off the ground when it broke. )</font>
Okay, I see now how it was. It's not unusual for me to get a little lift on my front end when digging in some good piles also and usually doesn't slam down hard when I'm doing it right.
I can't imagine why you had all the extra involvement in the front end though. Is there nothing obvious to see that would indicate how the problem happened? Stupid question I guess, since you posted you don't know, sorry.
John
/ dk40 front end #9
I'll get that movement in the front if the loader is in the float mode. If the loader is just set to one depth the loader will just cut straight into the pile. Maybe he is in float?
/ dk40 front end #10
I wonder if there is a problem with one of you universals or wheel gear boxes that causes something to bind up when the front axle is hanging free to one side or the other.
/ dk40 front end
it appears the ring gear did'nt have shims installed which may have allowed the backlash to move out and shear teeth. they will be shimming the new ring gear and hopefully take care of that problem.
/ dk40 front end #12
Jack,
Once you get the tractor back you can work the heck out of it but when the wheels dig and bounce up and down you will break it the next time. I have built a few kioti front diffs and it is not a pretty site when the blow apart. Work it hard but try not to bounce it because these front axles don't like it.
The front drive shaft does not have a shear pin, just two splice couplers on each end. As you noticed the diff will go before anything else. Good luck
/ dk40 front end #13
<font color="blue">Work it hard but try not to bounce it because these front axles don't like it. </font>
I don't know of any axle that likes that. /forums/images/graemlins/grin.gif
RedDog
/ dk40 front end
I was'nt bounceing the front end when it happened. but I will work it a little differently next time. although I hate to baby it because I'll never get any work done. mabe I'll just have to chip away at things in smaller quantities from now on.
/ dk40 front end #15
</font><font color="blue" class="small">( I was'nt bounceing the front end when it happened. but I will work it a little differently next time. although I hate to baby it because I'll never get any work done. mabe I'll just have to chip away at things in smaller quantities from now on. )</font>
Could be that just because it wasn't repaired correctly in the beginning, as you indicate, it had nothing to do with bouncing and you can continue to use it as you have.
John
2012 WESTERNSTAR 4900FA (INOPERABLE) (A67714)
2012 WESTERNSTAR...
2015 SUNDOWNER 25 T/A ENCLOSED TRAILER (A67714)
2015 SUNDOWNER 25...
8ft Fork Extensions (A66734)
8ft Fork...
2024 CATERPILLAR D1 LGP CRAWLER DOZER (A65056)
2024 CATERPILLAR...
1997 KENWORTH T300 4X2 S/A CAB & CHASSIS TRUCK (A69167)
1997 KENWORTH T300...
2016 KENWORTH T680 6X4 T/A DAY CAB TRUCK TRACTOR (A67148)
2016 KENWORTH T680...
