dk 35 tranny leak
/ dk 35 tranny leak #1
claytonalder
ontario CANADA
dk 35,david brown 990 red
My dk 35 has 30hrs on it now .
I can see tranny fluid leak between the first and second
sections of the tranny.
Has any one else had this problem.
I will be talking to my dealer shortly
/ dk 35 tranny leak #2
</font><font color="blue" class="small">( My dk 35 has 30hrs on it now .
Has any one else had this problem. )</font>
No
I had a small leak on a loader cylinder when my tractor was new, but the tractor itself (355 hours) has never had a single problem of any kind.
Hope the dealer fixs you up in a timely manor.
/ dk 35 tranny leak #3
</font><font color="blue" class="small">( </font><font color="blueclass=small">(I had a small leak on a loader cylinder when my tractor was new, but the tractor itself (355 hours) has never had a single problem of any kind )</font>)</font>
I noticed a few drops around one of my FEL cylinders, Did you fix it or have it fixed and what did they do to it?
YoYo
/ dk 35 tranny leak #4
Do you have a backhoe on it?
/ dk 35 tranny leak #5
yoyo,
I had a small leak on one of my loaders tilt cylinders when the tractor was new (pinched 0-ring).
I called the dealer and when the seal kit came in I just took the cylinder to the dealer, he installed the seal kit while I checked out the new machines, its been fine ever since.
If the tractor is no longer under warranty you can install a seal kit yourself, loosen 1 jam screw , remove 1 snap ring , put cylinder in a vice and pull the rod out.
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
UNUSED IRANCH IRTPL 10000 LB TWO-POST CAR LIFT (A64281)
UNUSED IRANCH...
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
2014 International WorkStar 7500 T/A Dump Truck (A61573)
2014 International...
Decorative Pelican Statue (A61574)
Decorative Pelican...
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
