DIY Spray Foam Insulation
   / DIY Spray Foam Insulation #1
sawduster98
Churchville NY
Kubota B7800
Does anyone have any experience with the DIY spray foam kits? I want to insulate my shop with closed cell foam and I found a bunch of online vendors that supposedly provide everything. Just curious if this is something that lives up to the vendor hype or just another project waiting to turn into a disaster. Thanks!
   / DIY Spray Foam Insulation #2
I tried to do my quonset hut 2 years ago myself. Turned out it didnt really work out so well. The product I had tried was called soy-thane, sprayed on via a 2 part cartridge with an air compressor. After I went through a case of the stuff and was completely covered, which btw does not come off anything very nicely, I had enough and sent the rest back. I ended up calling a company called MIG insulation and building. They were actually cheaper than i could do it myself. Should have just called them from the begining, but thought DIY would be cheaper... not the case. Also they were in and out sprayed 3-4 inches on ~3k square feet in about 4 hours. I had spent that long and sprayed about 100 sq. ft.
So if you want my advice, since youre in NY give them a call, and save your sanity, and money.
By the way I also looked into all of the other brands like tigerfoam etc etc. In the end these guys ended up spraying something like 4-55 gallon drums of 2 part product, but there were three guys spraying at a time, with heated guns.
Make sure and do this before it gets cold, b/c when its below 50 degrees F they wont spray, b/c the properties of the foam are severly limited.
   / DIY Spray Foam Insulation #3
I just bought a kit from foam it green. Its the 604 kit. I will be doing all my still plates to seal it for this winter. what ever is left over will be sprayed in the attic, or barn. I am not sure yet.
Other posts have said to make sure you mask, and plastic everything due to splatter.
   / DIY Spray Foam Insulation #4
Including yourself. You need a disposable body suit that covers you completely.
   / DIY Spray Foam Insulation #5
I did a little research on the DIY kits. Not a lot, but it didn’t take lone to figure out it wasn’t worth my time or money. From what I remember, most of the kits did a poor job. To get a kit that would do a half way decent job I would spend just as much money as I would to hire it done. That made it an easy decision.
   / DIY Spray Foam Insulation #6
Do not let it get on your bare skin, you might have to wear if off, plus some of it is an excellant adhesive.
Sounds like I should get some quotes from the pro's so I can make a better decision. How is this stuff priced...square foot? Any idea what the going rate is?
   / DIY Spray Foam Insulation #8
I just used some on my RV and ended up picking up a huge glob that fell off and shoved it back in before it hardened. Almost glued my fingers together. Anyway, Acetone worked wonders and cleaned me up as good as new.
   / DIY Spray Foam Insulation #9
I just gutted our 12 x 24 kitchen for a remodel. Got an estimate from a local spray foam co .......... 3 walls (opted to not to do the inside wall that abuts my diningroom) plus the underside of the roof. Three inches in the walls and five under the roof was $3,800.00 :confused2:. I almost crapped my pants. They price it by the board-foot.... so the thicker, the more money. I've been looking at the DIY kits also.
   / DIY Spray Foam Insulation #10
Current issue of Fine Homebuilding has an article on DIY spray foam.
2008 Ford F-550 11ft Flatbed Truck (A52377)
2008 Ford F-550...
BUYERS PREMIUM & PAYMENT TERMS (A54313)
BUYERS PREMIUM &...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2015 CHEVROLET C3500 SERVICE TRUCK (A51406)
2015 CHEVROLET...
