DIY Spray Foam Insulation
   / DIY Spray Foam Insulation #1
sawduster98
Churchville NY
Kubota B7800
Does anyone have any experience with the DIY spray foam kits? I want to insulate my shop with closed cell foam and I found a bunch of online vendors that supposedly provide everything. Just curious if this is something that lives up to the vendor hype or just another project waiting to turn into a disaster. Thanks!
   / DIY Spray Foam Insulation #2
I tried to do my quonset hut 2 years ago myself. Turned out it didnt really work out so well. The product I had tried was called soy-thane, sprayed on via a 2 part cartridge with an air compressor. After I went through a case of the stuff and was completely covered, which btw does not come off anything very nicely, I had enough and sent the rest back. I ended up calling a company called MIG insulation and building. They were actually cheaper than i could do it myself. Should have just called them from the begining, but thought DIY would be cheaper... not the case. Also they were in and out sprayed 3-4 inches on ~3k square feet in about 4 hours. I had spent that long and sprayed about 100 sq. ft.
So if you want my advice, since youre in NY give them a call, and save your sanity, and money.
By the way I also looked into all of the other brands like tigerfoam etc etc. In the end these guys ended up spraying something like 4-55 gallon drums of 2 part product, but there were three guys spraying at a time, with heated guns.
Make sure and do this before it gets cold, b/c when its below 50 degrees F they wont spray, b/c the properties of the foam are severly limited.
   / DIY Spray Foam Insulation #3
I just bought a kit from foam it green. Its the 604 kit. I will be doing all my still plates to seal it for this winter. what ever is left over will be sprayed in the attic, or barn. I am not sure yet.
Other posts have said to make sure you mask, and plastic everything due to splatter.
   / DIY Spray Foam Insulation #4
Including yourself. You need a disposable body suit that covers you completely.
   / DIY Spray Foam Insulation #5
I did a little research on the DIY kits. Not a lot, but it didn’t take lone to figure out it wasn’t worth my time or money. From what I remember, most of the kits did a poor job. To get a kit that would do a half way decent job I would spend just as much money as I would to hire it done. That made it an easy decision.
   / DIY Spray Foam Insulation #6
Do not let it get on your bare skin, you might have to wear if off, plus some of it is an excellant adhesive.
Sounds like I should get some quotes from the pro's so I can make a better decision. How is this stuff priced...square foot? Any idea what the going rate is?
   / DIY Spray Foam Insulation #8
I just used some on my RV and ended up picking up a huge glob that fell off and shoved it back in before it hardened. Almost glued my fingers together. Anyway, Acetone worked wonders and cleaned me up as good as new.
   / DIY Spray Foam Insulation #9
I just gutted our 12 x 24 kitchen for a remodel. Got an estimate from a local spray foam co .......... 3 walls (opted to not to do the inside wall that abuts my diningroom) plus the underside of the roof. Three inches in the walls and five under the roof was $3,800.00 :confused2:. I almost crapped my pants. They price it by the board-foot.... so the thicker, the more money. I've been looking at the DIY kits also.
   / DIY Spray Foam Insulation #10
Current issue of Fine Homebuilding has an article on DIY spray foam.
Ford Super Duty Pickup Truck Bed (A52377)
Ford Super Duty...
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2018 JCBTruss Jib Telescopic Hyrualic Boom (A53421)
2018 JCBTruss Jib...
2017 Ford F-550 Enclosed Service Truck (A53422)
2017 Ford F-550...
