DIY Mini Insulation Blower
/ DIY Mini Insulation Blower #1
Travelover
Elite Member
Washington
B7100
This is not about tractors, but I know that you guys (and gals) appreciate an imaginative use of "found objects". I had a spot on my roof where the snow always melted, so I knew I had a heat leak, but I couldn't get access to the cavity underneath. Yesterday I drilled a 2" hole in the wall so I could peek in with a flash light and sure enough, it was never insulated in there. My only access was this hole, so I made a mini cellulose insulation blower out of a cat litter bucket, a shop vacuum on blower mode and a short piece of plastic pipe. I just tossed in the cellulose loosely and turned on the blower. I was amazed at how well this thing worked. :D
/ DIY Mini Insulation Blower #2
Neat idea. I have a comparable situation but did not want the expense and hassle of renting a commercial blower. My Shop-Vacs do not have an exhaust port that I can hook a hose to. I wonder if a leaf blower would do the job?
Vernon
Vernon
I know people that use leaf blowers to keep their dryer ducts clean. Works like crazy :D
/ DIY Mini Insulation Blower #4
I replaced a shingle roof with a metal one this summer. I bought all materials from a local store including insulation. The store owner loaned me his insulation blower for free since I bought everything from him. I doubt the big box stores do that. But for a small job such as yours your ingenuity did the trick. I would imagine a leaf blower rigged up that way would work as well.
/ DIY Mini Insulation Blower #5
I am pretty sure the HD near our old house loaned out the insulation blower if you bought the insulation from them. I was going to add some insulation to the attic in the old house. After 10 years. Never got it done. :eek:
The only problem I can see with using a leaf blower would be the exhaust in an enclosed space. Might prove fatal.
Need to start another thread....
Later,
Dan
/ DIY Mini Insulation Blower #7
Later,
Dan
I have configured my "yard work" to allow me to get rid of small gas powered tools. If I need more than about a 40' extension cord it don't get done. Unless, of course, I can do it with my tractor.:D:D
Vernon
/ DIY Mini Insulation Blower #8
ELECTRIC YARD TOOLS! :eek:
Mentioned on TBN! :eek:
Shame!
I thought we was all about getting the big boy toys! :D:D If it ain't running at least gas it does not have the POWER! :D
Hmmm, where is the diesel powered hand held leaf blower.... Need to talk to my dealer... :D
Later,
Dan
/ DIY Mini Insulation Blower #10
GEORGE2615 What year is the Oldsmobile in your avatar. I had a simular one when I was younger. Mine was a 1954 88. Don't want to hijack the thread, just wondering.
Thanks Ken
/ DIY Mini Insulation Blower #11
Ken,
The Olds is a 55 Super 88. I also have a 29 Durant street rod. Both are for sale by the way. If anyone is interested send me a PM with your E-mail.
/ DIY Mini Insulation Blower #12
YES,YEs,Yes...
I've done it, I bought a used (very used, very rusted) insulation
blower, and replaced the blower (it was thru blower type)
with a standard craftsman ELECTRIC leaf blower. Tye wrapped
it right on the hopper end.
It is rated for continous duty, it has lexan blades to shred small
sticks. I bought a second unit when they were on sale again
as a back up. I ran it for probably 2 hours straight.
If you have a local cellulose insulation company (the actual guys that
grind up the paper) you can ussually get your cellulose cheaper
than at the "big box" stores, hence the reason to find your
own machine. For me it worked out that the box stores where $8.20
for a 23lb bag, verse $5.80 for a real 30 lb. bale from the local.
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
John Deere 4044R (A62177)
John Deere 4044R...
ATTENTION PLEASE READ (A64127)
ATTENTION PLEASE...
CF Grapple (A64127)
CF Grapple (A64127)
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
