DIY Home built compact tractor
/ DIY Home built compact tractor #161
Do ypi have the ratios vs. wheel sizes absolutely right ?
If not, it will eat away rubber. Maybe install a limited slip, or self locker from a race shop ???
If you lock the VW center diff, it will definately need the option of disengaging front wheel drive if you hit the road, at the speed this tractor is capable of....
Yes I do, dont have the numbers on me ( I'm at work) But it is very close with the front over driven just a tick.
If you look carefully at the wheel pics you can see the front hubs are selectable, I plan on locking or unlocking the front hubs as needed.:)
/ DIY Home built compact tractor #163
Smart, it sounds like you have your plan well made ;)
So far so good, I'm learning stuff from TBN'ers every day!
/ DIY Home built compact tractor #165
Back in the 70s Ford in their 1/2 ton pu used a ford rear end and a dana front end. these two did not have any gear raito that matched. some would over drive and some would under drive the front end. The center diff. when used handeled the difference ok......Larry
rpoage said:
This might be of interest if your using the Samurai transfer case.
Welcome to Trail-Gear Inc
I'm not using the T case at this time.
Thanks for the link, they have a good price on knuckle rebuild kits!:)
Tim
/ DIY Home built compact tractor #168
Looks good! Glad to see it coming along. Maybe just the photos but it doesn't look like you can turn very sharp before the tires hit the frame. I don't know much about sammys, maybe they don't turn too sharp anyway. Anyway, keep at it.:cool:
It turns lock to lock with the tires just barely nicking the inside edge.
It seems to negociate the obsticles in my garage pretty well.:p
In the pic its not quite to lock.
/ DIY Home built compact tractor #170
Before it gets too far along, you may want to look at the turning radius a bit more. Perhaps, move the front axle towards the rear some.
For a tractor, you want pretty tight turning radius. On my Yanmar, I have less than 1/2 the wheelbase, with what looks like easily twice the turning angle of the front wheels.
You'll never say "I wish this thing didn't turn so sharp".
/ DIY Home built compact tractor #171
Yea, I'm thinking "tractor" turning where the wheels go almost 90 degrees verses "truck" turning like you are useing. my bad;)
I was thinking about that, I could see that much angle on a 2wd.
Is it possible to get that much with a 4wd ? Seems hard to believe?:)
/ DIY Home built compact tractor #173
55ー is the standard on modern day tractor front axles. I assume cars wont do much more than 45ー
/ DIY Home built compact tractor #174
Wow, this is loking great. Thanks for taking us along for the ride so far.
Cliff
/ DIY Home built compact tractor #175
FWD tractors can turn sharper than trucks because of how the knuckle is designed. They don't use U-joints, they use 2 pairs of bevel gears. One pair goes from the axle shaft to a short vertical shaft going down and the other pair from the bottom of that shaft to the horizontal spindle. The knuckle turns, steers, on the same axis as the sort shaft. It could turn 90* or more just depends on the housing design.
If that is clear as mud, Sorry, best I can do with out pen and scratch paper.
Keep up the good work
DRL
DRL
Ok, makes perfect sense.
Thanks, Tim
/ DIY Home built compact tractor #177
Thanks for the link. I've been thinking about getting lower transfer gears for my Suzuki. Thats the lowest price I've seen.
Terrific installation instructions too.
/ DIY Home built compact tractor #178
That sounds about perfect. The normally acceptable range of gear ratios is 0-5% front tires faster than the rear. You should be good to go. Just pop in the engine, transmission, bend up some sheet metal, add steering, seat, lights, peddles, radiator, hoses, wires, make and intall an FEL, 3pt, hydraulic pump and lines and your done!
Nothing to it.
jb
Nothing to it.
jb
Thats it? How come I'm not done yet?:D :D
/ DIY Home built compact tractor #180
GT2,
I'm new to the board, and joined specifically because of this thread.
I was searching the web for people building their own tractors. They are few and far between, and your thread is by far the best example.
Thanks for sharing it with everyone. Great info and pics - I sometimes check in twice a day to see your progress and read the comments.
- Chris
Wacker Neuson AR14H (A60462)
Wacker Neuson...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
1997 Sherman and Reilly Drum Line Puller Tensioner Trailer (A59228)
1997 Sherman and...
2001 CATERPILLAR CB-634C SMOOTH DBL DRUM ROLLER (A60429)
2001 CATERPILLAR...
John Deere 3025E (A53317)
John Deere 3025E...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
