DIY Home built compact tractor
/ DIY Home built compact tractor
Progress!
Motor mounts. This is left side, modifyed stock mount.
The right side mount.
The rear trans cross member and the steering box. I have one more mount to add to the differential to help take the torque.
Closer pic of the steering box mount ( hefty 1/2" steel ), I'm going to add some gussets to it.
/ DIY Home built compact tractor #203
chrisser said:
BTW, here's an interesting site Tractor Page 2 - its electric, but some good pics
Interesting design but I would not be running a chopper with my legs straddling a PTO shaft. Good way to have a really bad day in a quick hurry.
/ DIY Home built compact tractor #204
WOW! Great to see this come back alive. I have to wonder about solid mounting the engine/trans. There is alot of shacking going on that can mess with all kinds of stuff down the line (ask all the kubota bx owners with broken air cleaner mounts, or any old harley "rigid" rider). Some rubber pads might be a good addition. I would also put a gusset on that steering box mount. It doesn't look like much "iron" at the weld point. Bit keep going on this! I'd love to see the end product in operation.:cool:
/ DIY Home built compact tractor #205
This is unreal! That thing is really looking good! My hats off to you.......
I'm glad you're pulling it off. When I was building my hot rod, I really got tired of people saying it can't be done. Most of the time, THEY couldn't do it. I proved them all wrong and I'm glad you are too.
Way to think outside the box.
Sooo.... I'm thinking out my steering geometery and I'm wondering what I should have for steering wheel turns, lock to lock.
Any ideas?
Thanks, Tim
/ DIY Home built compact tractor #207
I don't think it makes much difference. With the p/s it's gonna spin pretty easy. If it is a problem later ya can always lengthen/shorten the pitman arm (I wouldn't have a problem welding it on a slow moving tractor).:cool:
Well yeah, but as it sits now its 4 turns lock to lock. Seems a bit slow?
/ DIY Home built compact tractor #209
I guess it would be nice to be in the 2.5-3.5 range. If ya can find a box out of a camaro or some kind of sporty car I think they have quicker boxes. Other wise just add a couple inches to the pitman arm. Ya might want to put some "stops" on the arm in that case.
/ DIY Home built compact tractor #210
Fellas, I may have something to offer to the steering question, but in the end my suggestion may do nothing more than help me learn!
...... First off, what's the centre of gravity going to be like on that machine? Will it be high or low? Also, I recall that it has a shorter wheelbase. This would make it more prone to tipping, correct?
If the above is true, then I would not be too quick to decrease the turning potential as a steering system that turns the machine too quickly will decrease its operating stability. If it requires more turns of the steering wheel to make the turn, that means that the machine will turn more slowly and would allow the operator to have more control as they could make more minute steering adjustments.
These are kind of "off the top of my head" comments and I look forward to any responses as they will help me understand this whole fabrication process a bit better (as you can probably tell I have never undertaken such an impressive project as this one is turning out to be).
Thanks! :D
Thanks! :D
As far as tipping and center of G, based on what I've seen in other tractors I dont think mine will be much different than others on the market.
In the racing/ performance "world" the faster the ground speed the slower the steering speed, slower/faster.
I would think that quicker steering would allow you more control against tipping. ( allowing you to counter steer quicker)
My thoughts were that as I'm crusing thru the brush if I were to encounter a stump or something, haveing to crank 4 full turns lock to lock would be a bit slow.
I was hoping some of the tractor owners out there would tell me what thier tractors have for lock to lock.:)
Thanks, Tim
/ DIY Home built compact tractor #212
Four turns lock-to-lock is two turns from straight to full turn.
IMHO, I wouldn't worry about that right now. Get a few hours on the beastie & see how you like it. IF you're unhappy with it, then you have the option of lengthening the pitman arm, or shortening the steering knuckles. It's been my experience that these parts are forged steel & as such can be cut & welded easily.
BTW, without going out & trying it, I believe my JD4400 has about the same steering ratio.
/ DIY Home built compact tractor #213
Thanks, Tim
See - I told you I would be learning something! :D
Thanks for that info, it makes a lot of sense.
Sorry I can't offer any concrete info on the turns - my old tractor is in pieces right now and my steering wheel is in a pile with the other pieces.
/ DIY Home built compact tractor #214
I just went out and counted turns on my bx. I got about 2.75 lock to lock. It doesn't seem very quick either so I would shoot for something in the 2-3 range. It might be easier to shorten the steering arm on the axle than to make the pitman arm longer. either will work.
Thanks!
Ha! My truck has the same turn to turn (2.75).
So I think I'll shoot for that.
I've got the steering links mocked up. Please excuse my temporary tacked together tubes and rods and bolts:rolleyes:.
After dinking around on paper figuring lengths and angles I tack welded these brackets to the back of the front axle pivot plate.
I then tacked up this bell crank. I found those bronze bushings at Lowes. I'm going to add a zerk to the pivot tube.
Here is the pic of the bell crank temporarly installed.
On the right is the rod coming from the steering box, the rod on top going left to my temporary steering arm, and the tie rod (bottom) connecting the spindels. It works well with 2.25 turns lock to lock! Yes I know the tire/wheel is on the wrong side:p !
/ DIY Home built compact tractor #217
What incredible workmanship but still hate to see a Samuri hit the dust.
bx23barry said:
Kool! :cool: Why didn't ya mount the box up front instead of the bell-crank arrangment? :confused:
Believe me I racked my brain trying to figure how to do that.
I would have had to design a complicated set of shafts and universal joints to get over/around the engine and in the end all that stuff would have been in the way anytime I wanted to work on the engine.
Thats my story and I'm stickin to it!:D
/ DIY Home built compact tractor #220
It would have been much easier to use a steering cylinder hard mounted to the frame and just run hyd lines from the steering column. More $$, but easier!
jb
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
Cat CB24B (A60462)
Cat CB24B (A60462)
2012 HINO BOX TRUCK 26FT NON CDL BOX TRUCK (A59905)
2012 HINO BOX...
International S1900 (A61306)
International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
