DIY Home built compact tractor
   / DIY Home built compact tractor #81
You don't need a little 3 cyl perkins 400 series diesel for it do you? I have one I'm going to be selling in a few weeks that would sound mighty nice in there. Later, Nat
   / DIY Home built compact tractor #82
Does it have the same SAE bellhousing flange mount as the VW engine ?
   / DIY Home built compact tractor #83
Check in the photos and find a 2N,8Nor9N Ford and you can see the radius rods.
As Long As You Keep Going You Will Never Stop.
   / DIY Home built compact tractor #84
Here's a good shot of 8N radius arms.
Doug
   / DIY Home built compact tractor #85
True, but front axle have some axial movement on king pin.
On that home made tractor, there's no possibility for axial movement, so, idea is not applicable.
   / DIY Home built compact tractor #86
All he would have to do is weld a block on the side of the axle and drill it to facilitate a king pin and the idea is very applicable!
Limiting yourself is the fastest way to fail
   / DIY Home built compact tractor #87
If my memory hasn't gone completely, I believe the picture shows a nicely restored 9N.
   / DIY Home built compact tractor #88
Hi
You're memory is good that would be a 9n or my memory has gone as well.
Charlie.
   / DIY Home built compact tractor #89
Looks like a combination of 9N rear axel with 8N sheet metal. How much is 8N or 9N wouls require more study.
   / DIY Home built compact tractor #91
Yes I anxiously await some more progress pics. This is a very interesting project.
Al
Al
I havent had much time to work on the tractor, with better weather here I've been doing honey doos and other chores around the house.
I've kind of been held up waiting for my custom built steel wheels. I need them so I can mount up the tires and then set the height of the rear axle so that the tractor will be level.
Did some work on the rear axle.
I drilled and taped some spring perch, then welded a nut on the inside for more bolt engagement.
I decided to beef up the tube whare the mounting perch will go.
I slit a piece of left over axle tube in half and spread it a little so it would fit over the axle.
Patches welded up, perch's sitting there.
   / DIY Home built compact tractor #93
Don't know if anybody has mentioned this before, but your fotos are great: this looks like a good example of a tech repair manual, with clear images of whatever they're writing about! Nice.
   / DIY Home built compact tractor #94
That rear differential is quite atypical (besides you narrowing it). It looks like the front "input shaft" cover unbolts instead of the rear cover.
I just wonder how a person was supposed to "set up" a new set of diff. gears (since they would need to check the clearances between the ring and pinion gears and shim the input shaft accordingly) when they couldn't ever see how well the gears were meshing?
Just curious on how this could be done on one of these types of axles.
   / DIY Home built compact tractor #95
you set up the gears on a bench, instead of working on them while on the truck;)
this is a great thread...What are your plans for this unit? Tire size, weight, what kind of work are you planning on throwing at it?
I used my sammi to move some rocks last summer, but this is taking it to the next level :D :cool:
   / DIY Home built compact tractor #96
Thanks for the explanation- it makes perfect sense- the carrier and ring gear are bolted to that front plate and it all comes out together.
I am a little embarrassed that I had to ask...
24" front, 31" rear. Weight unknone.
My plan is to get it together with a hitch and see how it works pulling things around. You know, see how the speed and traction works out.
If everything seems good then I'll add a FEL, then a back hoe.
My uses at this time are just general moving dirt around and some stump/ root pulling.
   / DIY Home built compact tractor #98
Bummer, I just got to the last post. :-( This was very enjoyable to read through, now we have to patiently wait. It will be fun to watch it progress.
   / DIY Home built compact tractor #99
You may wish to upgrade the birfields in the front axle with some rings sold by most of the aftermarket shops. When the axle is steered they are the weak link. With the rigns, it moves the weak point inward. When steered straight (or with birfrings) the inner splines or the ring and pinion are the most common failure.
There are also upgraded axle shafts and birfs available with stronger components but they are expensive.
Apologies for taking the thread off-topic earlier.
   / DIY Home built compact tractor #100
GT2, take slowzuki's advice and get the birf rings (Trail Tough Products - Suzuki Stuff!) I've seen the birfs pop just under unmodified sammis. I'm assuming you'll be welding the center sections?? This will put even more strain on the lil' birfs.
Keep up the solid work...and keep the pics flowing:D
Kuhn FC400RG (A60462)
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2022 FORD F-150 XLT CREW CAB TRUCK (A59823)
2022 FORD F-150...
2018 Ford F-550 4x4 Altec AT37G Forestry Chipper Bucket Truck (A59230)
2018 Ford F-550...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A61306)
2008 Ford F-250...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
