DIY Home built compact tractor
/ DIY Home built compact tractor #61
GT2 said:
I was hoping that my heavy steel axle pivot plates (one on the front and one on the rear of the axle) would be strong enough to resist axle twist.
However your radius rod arms idea makes sense. Maybe I can add them later if it needs it.
Thanks for the ideas!:)
Tim
Just put a king pin as low as possible, and make it 4-5" long. Next problem is that for stability is better to have low king pin, as axle has smaller "sway" to side when one wheel go low. And driving shaft will have less side movement.
Radius arms can't be mounted here (as are on Bronco page), as they change wheelbase due to their movement radius.
/ DIY Home built compact tractor #62
Awesome project. Wish I had the time and skills.
Backing up a bit - you will want to be careful with the oil pan. The oil pickup is pretty close clearance wise to the bottom of the pan. In other words a dent can starve the motor of oil.
Best to have an oil pressure gage. These motors run high oil pressure especially cold. My 81 Pickup runs 140 PSI going down the road cold. Drops to 50 when warm.
And FYI in case you're not aware, you should have 52 HP stock and a redline of 5,700 or so. Way more oooomph that the Sami's gas motor. And you have performance options. If you can find an 86-92 turbo motor, upgrade the pump and injectors, add an intercooler and you're easily at 100 HP. Woohoo!
And one more thing: Everyone swears that the reverse gear in these trannys is really weak. I have not experienced a failure but I baby the truck in reverse because I've been warned. I hope it holds up in your application.
Keep the posts coming!
ZJ_HR said:
30" mens outer diameter of the wheel, not rim only. Am I right?
Yes, OD.:)
Whoo.. 100HP, I would proly twist the frame with that, and the higher torque!:D
Thanks for the info.
Tim
/ DIY Home built compact tractor #65
ahh... this is America, i forgot... When the Dutch refer to wheel size in inches, its the rim size beause only rim size and steel pipe sizes are measured in inches... ;)
/ DIY Home built compact tractor #66
I cant wait till you finish this beast,I have thought about doing something along these lines before but just never went thru with it.Keep up the good work.
/ DIY Home built compact tractor #67
Maybe I missed it somewhere...but how are ya gonna SLOW this down to a useable speed?
I drilled a pilot hole for the pivot point. First I drilled the frame, then held each plate up there and marked them.
Here the plates are hanging in place on a 1/4" drill bit.
Then I threw the plates up on my mill...err.. drill press and hole sawed out the 1.5" pin holes.
Then I hole sawed out the frame holes.
Heres a pic with the pivot pin in the plates and tube in the frame.
Now its off to my friends shop and use his lathe to cut the pin and bushings to length.:)
/ DIY Home built compact tractor #70
GT2, Good progress.
Couple points. As you probably know, the radius rods are to prevent front to back motion of the front axle. It is important that you add them! Otherwise the front frame will be twisted to junk on the first pot hole, rock, stump or other obsticle you encounter.
I would also beef up the front frame (and side frame where the radius rods attach) to take up the extra stress. Then again, I would rather weld than repair!
Good looking project so far!
jb
john_bud said:
GT2, Good progress.
jb
I assume you read the previous posts concerning Radius Rods.
My concern is that since the axle cant twist now, radius rods will twist the axle during movement and cause cracks.
Now I can make the rods long and lower the rearward pivot point so it is level with the axle, to lessen the " twisting and steering" effect. But I'm not sure if its going to be enough.
What If I used rods that had only one pivot point at the axle. This would help resist fore and aft movement of the axle, but not twist it?
Of corse this design would not resist any axle torque twist.
Bushing welded to the frame and surface ground.
Rear plate welded to the axle.
The front axle hanging in place all by its self!
Still need to modify the pin.
/ DIY Home built compact tractor #73
Like John B mentioned I still think you will need something like radius rods to keep the axle housing from twisting. The Ford ones I mentioned in the previous post are not solid steel to steel. They have rather hefty rubber bushings on them and considering the limited amount of travel this axle will have the rubber bushings would proably be able to flex enough to prevent binding.
Another suggestion. Your front axle pivot, is it going to be lubricated? You might consider center drilling and cross drilling it and installing a grease fitting so you can grease the bushing/pin to prevent wear.
My next run to the wrecking yard I'll take a look at some Ford rods.
Yes I plan to cross drill or something to lube the pin.
Thanks, Tim
/ DIY Home built compact tractor #75
GT2, you can't use any side links between the axle and the frame. I
think ZJ_HR stated it first: a radius rod won't work here.
All twisting resistance is in the center pivot, which looks substantial
as you built it. Look at any compact tractor....the front axle pivots
freely on the center pivot only. Grease zerks for your pivot are
mandatory, as stated.
One suggestion: put additional gussets or braces inside your frame
to further resist twisting the frame at the center pivot under 4wd load.
As an illustration, a recent failed pivot pin/bushing I replaced on my
JD955 caused only about 1/2" front-to-back movement at the
front wheels. Failure was due to inadequate lubrication. When replaced,
my new 25mm pin and bushing allowed maybe 1/16" movement.
/ DIY Home built compact tractor #76
I have worked on tractors for many years and have seen a few of them with a v shaped brace. Here is something that I sketched in MS Paint just to give you an idea of what I am talking about. This is the first time I have tried to attach an image, so I hope it works.
As long as both pins pivot on the same axis, this would work. You can adjust it up or down, or change the rearward angle of the brace for clearance as long as the pin centers stay lined up.
/ DIY Home built compact tractor #77
You are right, that's only correct way how to make axle stronger, but question is can it be fitted there?
Due to engine mounting and driving shafts?
Ahh, now that makes sense. But as ZJ said, I'll have to check for clearance.
Thanks for the idea!:)
/ DIY Home built compact tractor #79
GT2,
I was looking back through your pictures and found what Iwas looking for. In reply #39, the first picture in that set is a mock-up shot from the side. The transfer case and the front drive shaft are also in place (or somewhat near where they will end up, maybe :rolleyes: )
As I said before, the angle rearward and the overall length can be altered as long as the pin centers remain aligned. I hope you don't mind but I took the picture I refered to and sketched on my idea of mounting points.;)
This should give plenty of clearance to the drive shaft and if located in the right place, one cross member could also support the rear of the engine/transmission/transfer case.
Hope all of this makes sense.
MIke
/ DIY Home built compact tractor #80
Very ambitious! nice job.
2009 International 4300 Bucket Truck 55' (A62613)
2009 International...
2x4x8 Utility (A62613)
KUBOTA MI08S TRACTOR (A63276)
KUBOTA MI08S...
Bobcat S66 Skid Steer (A63688)
Bobcat S66 Skid...
213087 (A64276)
213087 (A64276)
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
