DIY FIRE STARTER
/ DIY FIRE STARTER #21
I split mostly sweetgum and as most people know it's very twisted and stringy when split. I keep a large box under the spliter and catch all the twisted trash that comes off. When the box is full I take an old dog food bag and fill it up, let it dry and makes the best kindlin short of fat wood. And it really doesn't take long for it to dry out.
/ DIY FIRE STARTER #22
I kinda cheat... I use some charcoal in my smoker that I cook several times a month in. Put the cubes in a chimney starter put that on the side burner of my grill turn it on for about 3-4 mins. Wait until the smoke clears then add to my firebox, add my fruit/hickory/oak wood as needed and I'm smoking in about 20-25 mins. That propane burner is perfect for this.
/ DIY FIRE STARTER #23
My preferred fire starter.
/ DIY FIRE STARTER #25
I've just purchased my fire starter for about the last 5 years since old newspapers has disappeared near me.
I stack about 4 pieces of my split kindling wood (about 1/2" x 1/2" x 18" long), then add 1 straw turd (GreenSpark), and then add about 4 pieces of "fatwood", and light with an electric match.
I usually purchase 50 pounds of Fatwood and 3 boxes of GreenSpark each summer of fall just before winter.
Here's a link to each:
KC
https://www.amazon.com/dp/B07FPQVLFH?ref=ppx_yo2ov_dt_b_fed_asin_title
/ DIY FIRE STARTER #26
Mine as well and/or one of those new style butane torch lighters. Carry it in your pocket and will start a fire almost every time.
When I get one going, I'll use my Harbor Freight Bauer 20 volt Li-Ion blower to get it up to 'speed' real quick like... Amazing how that 200 mph blast of concentrated air promotes rapid combustion, plus you can spot direct the air exactly where it's needed.
I may add some used motor oil to the fire just to get rid of it but I don't use an accelerant to start it other than the above.
/ DIY FIRE STARTER #27
KC
Propane torch or torch lighter is much less expensive and have other uses as well...
/ DIY FIRE STARTER #28
I am a school teacher. To start my wood stove I use old worksheets and some dry kindling, leave the door cracked for 10 minutes instant fire. If I am making an outdoor fire at home or on the property I always have a mix of drain oil and old diesel in a 1 gallon jug. I use the propane torch trick if I am out.
I am going need to make some of those sawdust and candle wax starters for camping. Lord knows I have enough, the mill makes 5 gallon in about 3 or 4 cuts of a 10' log.
/ DIY FIRE STARTER #29
When we go 'camping' the wife turns on the propane stove and cooks the meal or uses the oven to bake stuff. I like to rough it in comfort.
2019 BOBCAT E32I EXCAVATOR (A59823)
2019 BOBCAT E32I...
pressure washer, and trailer (A56859)
pressure washer...
2012 GENIE GTH844 TELESCOPIC FORKLIFT (A62129)
2012 GENIE GTH844...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2006 Nissan Frontier Ext. Cab Pickup Truck (A59230)
2006 Nissan...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
