Diverter valve
/ Diverter valve #2
"L" is the drain port. IF & I repeat IF I am interpreting the data sheet correctly you can use the valve to 210 Bar without the "L" port and 315 bar with the "L" port.
/ Diverter valve #3
I have sold a couple of them and own one, oldnslo is correct no drain needed until you go above 3000psi. CJ
/ Diverter valve
So is it a built is pressure relief that you would pipe back to the tank if you ran above 3000 psi? If your not running above that do you just plug it or leave it open?
/ Diverter valve #5
That port vents the armature tube assembly area which appears to pressure limited to 3000 PSI. Below 3000 PSI just plug the port, above 3000 PSI this port must be connected to tank.
No relief valve involved
/ Diverter valve
Cool. Thanks all.
2001 33 Ft. Chris Craft Boat with a 2006 Rant 36ft T/A Boat Trailer (A61574)
2001 33 Ft. Chris...
(5) 2" X 20' STEEL PIPE (A64281)
(5) 2" X 20' STEEL...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
2013 Ford F-350 Knapheide Service Truck (A61573)
2013 Ford F-350...
New/Unused CFG Industrial H12R Mini Excavator (A65579)
New/Unused CFG...
