Diverter valve
/ Diverter valve #2
"L" is the drain port. IF & I repeat IF I am interpreting the data sheet correctly you can use the valve to 210 Bar without the "L" port and 315 bar with the "L" port.
/ Diverter valve #3
I have sold a couple of them and own one, oldnslo is correct no drain needed until you go above 3000psi. CJ
/ Diverter valve
So is it a built is pressure relief that you would pipe back to the tank if you ran above 3000 psi? If your not running above that do you just plug it or leave it open?
/ Diverter valve #5
That port vents the armature tube assembly area which appears to pressure limited to 3000 PSI. Below 3000 PSI just plug the port, above 3000 PSI this port must be connected to tank.
No relief valve involved
/ Diverter valve
Cool. Thanks all.
Pemberton Inc Komatsu Forks and Frame (A64194)
Pemberton Inc...
(2) 5' TRAILER RAMPS (A64280)
(2) 5' TRAILER...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
CATERPILLAR CS44B...
2005 Fontaine FTW5-8048SLW 48ft. 38 Ton T/A Piggyback Flatbed Trailer (A61573)
2005 Fontaine...
Parker Spreader (A64119)
Parker Spreader...
