Ditch digger
/ Ditch digger #1
sandman2234
Super Member
Jacksonville, Florida
JD2555 and a few Allis Chalmers and now one Kubota
I do just enough maintance on a dirt road to allow traffic to make it down it. I don't live down it, don't own property on it, etc, but my sister in law lives down it so I try to hit it ever now and then with the box blade. With all the rain we have had lately, the road is getting rough, and the ditches aren't helping. Basically the ditches are grown over on one side with trees, and the other side has an embankment that people just keep riding up to stay on the smooth sand and it kills the grass, and the sand washes away. If the ditches were cleared out, so they would carry water, I feel like the road would have a better chance. I thought about building a middlebuster, but the trees along the side of the ditch keep me from pulling something behind the middle of the tractor. I thought about using the box blade with just one ripper down, but I don't think it would break up enough dirt, or go deep enough to help. Basically what I need is some sort of plow like a middlebuster that I can pull from one side of the tractor without it hurting my tractor. Side pull on the 3pt hitch can't be good for the lower links.
Anyone got any ideas?
No, I don't have a backhoe, nor a FEL, otherwise this wouldn't be a problem.
David from jax
/ Ditch digger
The reason I posted this in the build it yourself forum was hopefully to find someone that had built or seen something like an offset middlebuster that would do a ditch but not put too much strain on the lift arms. The tractor I have to pull it with is a JD2555 and should take some abuse, but I don't want too much on it. Anybody seen anything that might reach out to the side and cut a shallow ditch? Since this is a non paying job, hopefully someone has an idea that I can build out of my current allotment of scrap.
Thanks,
David from jax
/ Ditch digger #3
Sandman,
I built a device that bolts the the far side of the yard box. I had to drill a few holes but, easy on and easy off. Kinda is like a flat plate pointing forward 45 deg, 18" wide.
Patrick T
/ Ditch digger #4
David,
I hear what you are saying, but all I can envision is something like a standard rear grader blade, with a piece of channel of other metal bolted to one end, which is still going to give some sideways strain.
There is always just a plain old grader blade, tipped hard to the ditch side, so it's cutting a Vee.
I guess to minimize the strain, you would center the subsoiler/middle buster/shank just outside your rear tire and drvie as close to that side as possible?
Something ike a plow blade mounted off-set? It would pull the dirt up onto the road surface for further grading.
If you take it a little at a time, it may not be as much side-to-side strain as you think. If you try to cut a 16" deep trench in one pass, then, yes, it would probably be a concern.
Good Luck, I'm curious to see what others have up their sleeves for this sitaution?
/ Ditch digger #5
I would think you could make a mount for a cultivator bar on the the mid-mounts and mount a chisel/sub-soiler on the end of the bar. Most old row crop cultivators were mid mount like that.
/ Ditch digger
Hmmmm, that is a thought, but it will still stick out a long way, because my tractor is wider than my 6' boxblade. I haven't measured it with the turf tires on it, but with my ags on narrow rims, it is just under 6'6". I looked at using the box blade as a guide but it is still way out there. I just went out and measured it, at 7'7" with the turf's on, it is wider than my boxblade and that puts it over 30 inches from the side of the engine frame which is where I could hang it.
I think my best bet might be to build one for the 3pt but just make it so that it doesn't pull too much dirt, so as not to put any undue stress on the lift arms. The biggest thing that worries me is hitting a big root or a buried chunk of concrete that somebody put trying to help the road. The added to the size of my tractor will put a lot of twist on the lift arms.
I wonder if building two would work. Make one with a narrow digging blade that will go deeper and deeper, then change over to a wider one that will move the dirt out. I might need to use a turning plow to get the dirt out of the hole so I don't have to dig it.
David from jax
/ Ditch digger #7
the thought comes to mind of attaching somthing to a hay wagon type frame to do that. you can also adjust the weight on the wagon to remediate the bounce/side pull. with 4 wheels it would be much harder to get pushed aside. it would also be on the drawbar so no tear on your arms
/ Ditch digger #8
This is just a thought and keep in mind I have never tried to pawn myself off as a design guy.
Why dont you come off the side of your box blade with an arm and then attach a middle buster or something like that to the arm. if you set it so that it is deeper than the box blade you can put the box blade down flat on the road and that would help with the twisting of your three point. you will still have some side stress but it should be carried through the box blade and both lift arms will feel some of the stress. Would that work ?
/ Ditch digger
gemini5362
That thought has crossed my mind, which is the reason I walked out and measured my tractor width last night in the middle of writing a post. Due to the amount of time since that ditch has been messed with and the roots that are going to be really close to it, I am afraid of almost any side pull. I think mounting it on the side of the boxblade and dragging the box might help a little, but probably not enough to withstand the energy of a large root. If I do it that way, I will run the tractor in as low a gear as possible and several light cuts.
Kendrick,
I don't have a hay wagon but I do have an axle with a frame (2'x5') that I could use. I recently pulled the tires and wheels off it and used them on my JD but I might consider putting a set of tires on it and mounting a tongue on it. I have enough junk around here that I could weight it down so that it doesn't slide sideways too badly. Might look into mounting it like a Swisher Mower. I am not sure just how much it will take to keep it in line.
I wonder if the best thing wouldn't be to just take the Ford out there with the boom mower on it and just clear it wide enough for the JD to do it straight line. Doing that much work maybe more than I was bargaining for, though.
David from jax
/ Ditch digger #10
I don't know how overgrown the ditches are but I've had great successkeeping water running in ditches. Simple trick is to ride the tractor with 1 front and 1 rear wheel in the ditch once in spring and again in fall when the soil is soft. This keeps the ditch clear and about 6" deep along the sides of my deive and at the edges of my fields.
When I first got the property water ran across the fields all spring. I made ditches with a 1 bottom plow along the edges and since I have kept them clean using the weight of the tractor, it has eliminated my problem.
/ Ditch digger #11
A force of 1 ripper leg on the side (instead of all 6 or 10 of them spread over the full width) wont hurt the tractor nor the 3pt hitch.
Can you extend one 3pt hitch pull rod to angle the box blade ?
another idea is a kind of plough i've seen road crews use, to plough a pathway along freshly paved asphalt, for kerbstones.
They simply bolt a 2 foot piece of steel plate to a loader bucket and drive along the road edge, with the bucket lip as a gauge over the pavement and the steel plate ploughing a path for the kerbstones at the correct depth.
Maybe you'll just have to tramp the brush first in reverse, then start working the actual dirt...
/ Ditch digger #12
Is this a private road, or county road? Seems like you need to get the commissioner to do his job. Watch for phone lines and other utilities that might be buried there.
/ Ditch digger #13
Hi David, Why not use your trencher in a sideways position to flip the dirt from the ditch back on the road. The trencher should leave a nice half round trench. Just drive slow.
/ Ditch digger
The road is a private road, and up until last year was privately owned property. However the owner quit paying the taxes and the county got it for back taxes. The width doesn't meet the required amount to get it brought up to a real road, which would allow for ditch work and PAVING. BTDT on trying to get some help. The adjoining owners won't donate enough property, so it isn't going to happen that way either.
I have considered J_J's idea, but the U-joints won't allow enough deflection to get the trencher turned sideways enough to cut the channel that you envision. Good idea though!! I do have another one of those wheels and thought about using a pillow block bearing and a straight shaft off the pto. Only problem with that is the same with all the others, which is getting it far enough offset to reach outside the tire track. I could use it for other projects if I thought it would work for this one, but building it for this one probably isn't a good idea.
Putting the boom mower back on the Ford and havng a go at the brush and small trees is probably the best answer, and then just pulling a middlebuster behind the middle of the tractor. That is just a lot of work, especially when doing it for nothing.
David from jax
On Edit:
I started to buy the roadway property for back taxes, but realized that it was always going to be a roadway, and in reality nothing more than a way to spend money (taxes) because nobody is going to want to buy it, should I decide to sell. I can't close it down and hold the access to their houses ransome, so why should anyone want to buy it?
David from jax
/ Ditch digger #15
The road that I live on I maintain I use my scrape blade. my blade turns on two axisis I turn it to about 22 degrees horizontaly then tilt it verticaly 45 degrees. I dont know if that makes sense the way i described. But basicaly it turnes my scraper into a plow, perfect for cleaning as well as cutting ditches.
/ Ditch digger
No question, a multiangle scrapper blade would be just what I need for this but unlike Toolsorbust, I don't have one. I might could "borrow" one, but taking the chance of tearing up a borrowed implement doing charity work really isn't a good idea. That is a lose-lose situation for me. I will probably just have to bush hog the edge of the road and work around the larger trees. I can take out the larger trees if I take the Ford over there, but I could be opening a can of worms doing that, so I think maybe just a bush hog and then pull a middle buster behind that may work. Can't hurt...
David from jax
/ Ditch digger #17
Hi David
I have one.
/ Ditch digger
Thanks J_J,
I appreciate it if you would loan it to me, provided I don't do the clearing with the bush hog. I am waiting on a return call from the city to make sure I am not going to be getting in hot water by messing with a road that is now their property. Running the boxblade across it or clearing the ditch is one thing, cutting the brush is another.
David from jax
I looked to see if you had posted anything in the following post, to see if you had an adversion to loaning out implements. Mr.Jimi is on that list, but your not, so hopefully you and I can get together on it.
http://www.tractorbynet.com/forums/owning-operating/109143-sharing-neighbor.html
/ Ditch digger #19
J_J said:
Hi David
I have one.
Way to go JJ. I guess it ain't just a South Carolina thing huh?
/ Ditch digger #20
We have cities here that has ordinances that say if the grass or brush in your yard gets out of hand either you have to cut it or they will and charge you for it. If a city owns the road and they have such an ordinance I would ask them when they are going to clean up their land
2023 CATERPILLAR 259D3 SKID STEER (A65056)
2023 CATERPILLAR...
Generator (A64553)
Generator (A64553)
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A66738)
2021 Mercedes-Benz...
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
2002 12ft Haulmark KD7X16WT2 Cargo T/A Enclosed Air Cascade Trailer (A66738)
2002 12ft Haulmark...
IRANCH HYDRAULIC THUMB CLAMP (A67714)
IRANCH HYDRAULIC...
