distributor woes
   / distributor woes #1
1st fws
Holden,La.
1955 800 ford utility 5 speed non live pto
installed new aftermarket distributor on 55 850 ford.won't start.
   / distributor woes #2
HMM?
6 volt or 12 volt??
Do you need a new rotor?
is the cap tight to the base?
Were the wire ends pushed all the way in to create contact?
Healthy spark?
good coil
Battery up to snuff?
   / distributor woes #5
The big question not answered, why did you replace the distributor? Did someone tell you it was bad? Now to the serious stuff, did you note the position of the rotor button before removing? Could the coil be bad? Have you tried rotating the distributor back and forth as the engine is being cranked?
2015 Ford F-350 Utility Flatbed Truck (A51691)
2015 Ford F-350...
2020 KUBOTA RTV...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
2004 Ford Taurus SE Sedan (A51694)
2004 Ford Taurus...
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
