Dismounting FEL
/ Dismounting FEL #1
gltrap54
Topeka,KS
B3200 Kubota
Obvious noob here............ I'm trying to dismount my Woods 1006 FEL from my B7500. I've figured out everything except one hydraulic quick connector that won't budge. Does the hydraulics have to be shut off to disconnect any of the hoses? Also does any of the hoses need to be reconnected to the tractor once the FEL is detached?
/ Dismounting FEL #2
Sometime's you get pressure in the hose your trying to disconnect and it won't move.Just move your control stick a little all ways the bucket or arm will move just enough to releast the presure.You most likly have a little much angle on your bucket when trying to drop loader.It will happen a few times to you get use to the operation of your loader then it will go off and on like your an old pro after a while. I am not sure about the hose's being reconnected on your loader if they have quick connectors I would think not,just caps to keep dirt out.Check your manual and Enjoy
/ Dismounting FEL
Thanks for the input! I'll give it a shot................. =8^)~
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2007 Ford Explorer Crew Cab Pickup Truck (A64556)
2007 Ford Explorer...
2015 Global Environmental Street Sweeper (A64553)
2015 Global...
6' 3-Pt Disk (A66285)
SHOPBUILT T/A TRAILER (A64278)
SHOPBUILT T/A...
2017 CATERPILLAR 259D SKID STEER (A65053)
2017 CATERPILLAR...
