Disc Opinions
/ Disc Opinions #1
jacain
Richmond (Chesterfield), VA
Ford 2600 Ford 3910
Need a disc for planting small experimental food plots for my sheep and deer. Neighbor wants $300 for this. Looks to be in good shape. I think it's a 7'. I know weight is the key to a nice disc, hence the segmented wheels because it's light. Was just thinking it would still be handy for breaking up a couple few inches of the ground. Thanks in advance for any opinions/advice! PXL_20200928_121040049.jpegPXL_20200928_121058063.jpegPXL_20200928_121138798.jpegPXL_20200928_121104026.jpeg
/ Disc Opinions #2
It's adjustable and from the looks of the disc blades it has been used very little , in this part of the country it would be considered a great deal , you may have to make several passes in unbroken ground but it will do what you want. I have a Bush Hog brand that is almost a twin to that and I have done everything with it from making beds to plant watermelons on to small deer plots, and while I have larger disc's offset and leveling, I would never get rid of my little harrow.
/ Disc Opinions #3
In my part of the country, that's a steal. I paid $450 for a Ford 202 disk and the guy who sold it to me had other people beating down his door to buy it out from underneath me while I drove my trailer back to pick it up. That disk should more than do the job.
/ Disc Opinions #4
I would jump on that. Nice that it is 3ph and you can easily position the thing.
/ Disc Opinions #5
I paid much more for a similar disc. Yours looks almost new. Depending on soil type and condition, you may need to add some weight to help with penetration. I use two poly 55 gallon drums with various amounts of water added to provide needed weight to penetrate my Alabama red clay soil. A poly 55 gallon drum filled with water weighs about 460 lbs. Two barrels (one per side to balance) partially filled will give you a nice bite. A couple of welded brackets will provide a cradle for the barrels. Speed will also determine tilling effectiveness. Good lick.
/ Disc Opinions
Thanks for the replies everyone! Definitely very similar to the Bushhog brand. Love the blue color since it matches my tractor. Lol! I'll try and post up a good video of me using it once I get the bearings greased up. Everything seems to spin nicely though.PXL_20200928_200339397.jpegPXL_20200928_200345960.jpegPXL_20200928_200355495.jpegPXL_20200928_194903630.jpegScreenshot_20200928-130417.jpeg
/ Disc Opinions #7
I don't know about now but those discs used to be a dime a dozen in SC farm country. I have one that I've hardly ever used. Not in quite the shape of that one but it works.
/ Disc Opinions #8
I would buy that even if I had nothing to pull it! I know a bargain when I see one. Stuff like that goes only two ways these days. Good quality and more expensive (by the day it seems) or poorer/lighter quality.
/ Disc Opinions #9
Thanks for the replies everyone! Definitely very similar to the Bushhog brand. Love the blue color since it matches my tractor. Lol! I'll try and post up a good video of me using it once I get the bearings greased up. Everything seems to spin nicely though.View attachment 671220View attachment 671221View attachment 671222View attachment 671223View attachment 671224
You made a good purchase for $300 bucks, now all you need to do is weld you a couple of eye nuts on the back to attach you a nice heavy drag like a piece of railroad iron to smooth the ground behind you on your last pass.
/ Disc Opinions #10
Not sure if any holes are hidden under the plates or not, but cased upon what can be seen, both the front and rear are set to a center position. You have at least 1 more and 1 less aggressive setting on both gangs.
There are many ways to increase weight of the disk, all depending upon how much you wish to add and your fab skills. Some have been suggested.
Discing from different directions (90 and 45 degrees) will help to break up soil also.
/ Disc Opinions
Thanks for the info! What grease do you recommend for the bearings?
/ Disc Opinions #13
As for grease, the best is the grease you will actually use. Meaning you can buy a high quality grease but if you do not use it, it does little good in fact it does less good than a cheap grease that is used each time the disc is used.
All that said, buy a good quality grease, never the cheapest and use it before discing.
/ Disc Opinions #15
you can add weight to the disc as needed. used to put 8x8x16" concrete blocks on my old one.
/ Disc Opinions #16
Not too shabby before I changed the angle to the most aggressive holes. Then it was awesome. Definitely could have played with the top link some. I really need to get a hydraulic top and side link.
Ford 3910 Hawk 6' Disc First Pass - YouTube
Ford 3910 Hawk 6' Disc - YouTube
Ford 3910 Hawk 6' Disc Max Angle - YouTubeView attachment 671721View attachment 671722View attachment 671723
Don't know how many passes you had to make, but you have that ground plenty good enough to plant a food plot.
/ Disc Opinions
Not too many. I think it's perfect for what I'm trying to do. My hay guy has is going to sell this cultipacker to me for real cheap once he's done with it. I should have everything I need then.
/ Disc Opinions #18
Earlier, I recommended adding weight to a disc using 55 gallon poly barrels and water. Here's my reasoning;
1- Poly barrels are cheap and easy to handle when empty. They can be bought for about $15.00 each and weigh about 25 lbs. empty.
2- One added on each side of the fore and aft center of the disc can help cutting into hard soil.
3- The weight is easily controlled with water.
4- The barrels can also double as a tank for a home made spray rig.
5- I also haul water for my orchard trees when we have dry spells here in Alabama.
A simple welded angle iron rack will keep them in place on your disc.
/ Disc Opinions #20
Late to the party, but that was a fantastic purchase. def38's suggestion to use poly barrels is a great idea. I may try that for our discs at hunt camp. None of us can weld but I could make up a 2x4 frame and bolt it or ratchet strap it to the disc frame.
At our hunt camp we have been rototilling and last year tried discs on a couple of sites...worked OK. I am experimenting with no-till for the food plots on my property as I do not have either a disc or tiller.
