Disc Opinions
/ Disc Opinions #21
Late to the party, but that was a fantastic purchase. def38's suggestion to use poly barrels is a great idea. I may try that for our discs at hunt camp. None of us can weld but I could make up a 2x4 frame and bolt it or ratchet strap it to the disc frame.
At our hunt camp we have been rototilling and last year tried discs on a couple of sites...worked OK. I am experimenting with no-till for the food plots on my property as I do not have either a disc or tiller.
If you can wait late enough until you have had a good frost and then no-till it works better, when your food plot seed has to compete with established native grass, the grass always wins, the other option is a good herbicide to kill the native grass and weeds about 3 to 4 weeks prior to no-tilling in your food plot seed.
/ Disc Opinions #22
Proper discing is an art. Just as proper moldboard plowing.
There are many disc varieties. Just as there are many intended purposes.
You stole this disc. Very good purchase!!!
/ Disc Opinions #23
You should occasionally check your individual disks for looseness if they get loose tighten up the nut on the long axle that holds the rack together.
/ Disc Opinions
This disc is awesome. Actually found another one a little heavier than this one from my hay guy. Going to sell this one to my buddy for what I got it for and get the other one. PXL_20201030_122855914.jpegPXL_20201030_123004980.jpegPXL_20201030_144711268.jpeg
/ Disc Opinions #25
That's a great choice, the ones pictured above look to have sealed bearings... Less maintenance and less work to change them out if needed..
And already comes with a chunk of railroad iron.
That's a no brainier there .
2014 Ford Focus Hatchback (A66738)
2014 Ford Focus...
2014 PETERBILT 579 MID-ROOF SLEEPER (A67714)
2014 PETERBILT 579...
1999 Johnson 25hp Boat Motor 225hp 2-stroke Boat Moter (A66738)
1999 Johnson 25hp...
217982 (A65054)
217982 (A65054)
Case SV300 High Flow Compact Wheel Loader Skid Steer (A66734)
Case SV300 High...
2018 Mazda 6 Sedan (A66738)
2018 Mazda 6 Sedan...
