Disc 18 x 20
/ Disc 18 x 20 #1
Gizmo36
Platinum Member
East of Duewest S.C.
A friend of mine has a Kingkutter 18 x 20 disc harrow he wants to trade me for my 16 x 16 disc harrow . will a 2210 Yanmar pull the 18 x 20 . dose any one have a set that big for there 2210.
/ Disc 18 x 20 #2
I think the 18x20 is too big. The 16x16 KK angle iron disc is 460#, the KK 18x20 angle iron disc is 560# and the KK 18x20 box disc is 790#.
Danny
/ Disc 18 x 20 #3
Danny, what's the engine in a 2210? Is it just a 2TR20A-X with the injector turned up, or larger displacement?
/ Disc 18 x 20 #4
The YM2210 has a 2T90 engine, most engine parts will interchange. The OEM piston on the YM2210 has 1 piston ring below the piston pin and the YM2000 has all the rings above the piston pin.
Danny
/ Disc 18 x 20
I am going to see if I can pull it. will let you know. Danny is the 2210 the only one that has a ring below the piston pin. and will that piston fit in any of the three cylinder.
/ Disc 18 x 20 #6
Gizmo36 said:
I am going to see if I can pull it. will let you know. Danny is the 2210 the only one that has a ring below the piston pin. and will that piston fit in any of the three cylinder.[/QUOTE
I don't know of any off hand, but as many engines yanmar builds there could be. I don't know of any 3 cyl engines that the piston will fit, but there could be.
Danny
/ Disc 18 x 20 #8
Similar experience here.
My tractor apparently has the same size engine, and it came with a 5 ft 9 inch "Leinbach 97" disc which has sixteen 18" pans. The previous owner said he was told when he bought the tractor from its long-time owner that they were used together for years in a flood-irrigated flat walnut orchard, but he couldn't pull it in a dry pasture.
Everything around me is on a slope and I can't pull it uphill above a crawl, after I put enough weight on it to tear up grass.
Here's an old thread with more discussion and a photo of this Leinbach 97 in use.
http://www.tractorbynet.com/forums/yanmar/66394-what-size-disc-do-i.html#post739917
/ Disc 18 x 20
The 16 X 16 pull so easy I thought I could pull it. but it did not work.hard ground it was ok . but in soft dirt it would not move it.
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A65057)
2001...
2018 GENERAC MOBILE PRODUCTS MTL6S (A67714)
2018 GENERAC...
2008 Sterling L7500 Series T/A Vactor 2115-824 Combination Sewer Jetter Vacuum Truck (A66736)
2008 Sterling...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
THERM DYNAMICS TD 375 FLAMELESS HEATER (INOPERABLE) (A68842)
THERM DYNAMICS TD...
1997 Ford Expedition 4X4 SUV (A66738)
1997 Ford...
