Dirt SLIP help needed
   / Dirt SLIP help needed #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
A close friend of ours is having a problem with the side of his driveway slipping. Around here slips are not unusual but do cause a lot of issues (recently part of our airport overrun area slipped and crushed a church and is causing all kinds of problems for example).
Anyway does anyone know of a good site or source of information on stabilizing the ground and fixing slips? The area that slipped on his property is roughly 40' long and it goes over a 50-60' hill so it is not really something you can just fill in without a major construction project. The other issue is he has a 500' more of his driveway that could "slip" so any information is helpful.
Thanks
   / Dirt SLIP help needed #2
I would start with the NRCS staff at your local USDA office.
I am not sure whether they will assist homeowners, but they have designed water bar and stream stabilization projects for my farm at no charge. If they can't help, they may be able to put you in touch with someone who can.
Steve
   / Dirt SLIP help needed #3
We can't help you with this one. We live where it's so flat I can look out the window and see every town in every direction for 12 or so miles. A 60' hill would be a mountain here. Good luck.
   / Dirt SLIP help needed #4
You can watch your dog run away for two weeks!
   / Dirt SLIP help needed #5
We let him loose. He's got a good mile to run before he bothers the neighbors. We can see him going the whole way. I can catch him on the atv before he gets there!
   / Dirt SLIP help needed #6
I suspect that slips are a result of layers of clay that 'slip' when water gets between or under the clay.
Looks like a common correction is diverting that water or planting deep rooting trees as well as seeding a tough creeping grass to hold things together.
Around here most slips seem to follow deep frosts after a very rainy summer with a less than usual snow cover.
Our highway engineers generally install large boulders at the bases of slips and plant deep rooting trees as anchors. On larger slips they create steps every 10 12 ft in height.
If the slope was not excessive I would think that 3-4' boulders placed on the downhill side would go a long way to retaining any slips, that and a dense ground cover to fuse and protect the surface.
I always think of a slip as an earthen avalanche. Layers of different densities of material with the heaviest being on top.
   / Dirt SLIP help needed #7
Best be looking at an Engineer that deals with dirt. Your problem may be the underlying material. As such coring etc. may be required to determine the problem.
If the substrata is a type of clay that can liquefy with moisture and vibration it may be more than an inconvenience.
   / Dirt SLIP help needed #8
Agreed. This is not something you can fix in a weekend with a tractor and have it be a permanent fix. There is a reason the soil cohesion has decreased most likely due to a water infiltration. The water must be dealt with or it will be a recurring problem. How was the driveway put it? If it was not keyed in with an anchor trench with proper drainage and properly back-filled with compaction testing, the slope may never stabilize. I had a whole class in college devoted to mass-wasting movements. Your best bet if you want to try and fix it is to find a Professional Engineer with a specilaiztion in Geo-Tech and a drilling contractor with a coring rig to be able to see what the support materials area. Good luck!
   / Dirt SLIP help needed #9
Like already suggested, talk to a soil engineer. Trying to correct it yourself will often make it worse.
Eddie
Thank you all for your input. I will pass this information on to him immediately!
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2009 MIE Vessel and 2017 LORT Trl (A50324)
2009 MIE Vessel...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2020 ASV VT70HO Skidloader (RIDE AND DRIVE) (A50774)
2020 ASV VT70HO...
2003 PETERBILT PB 330 WATER TRUCK (A51243)
2003 PETERBILT PB...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
