Dirt Scoop Customization
/ Dirt Scoop Customization #1
MikeFLA
Central Florida
Kubota B7500
Bought a digital camera yesterday. Thought I would post a few pics of a TSC dirt scoop with a couple of additions.
The dirt scoop is my default 3pt implement. I am always in need of moving a trailer around my property. I designed a simple hitch that utilizes the rear facing pins on the scoop.
I also quickly tired of the "rope to dump" arrangement and fabricated a dump lever that I can reach from my seat.
Another angle
Dump Lever
Another shot of dump lever
/ Dirt Scoop Customization #5
Nice engineering. Good job with the pictures.
Have fun with the camera /w3tcompact/icons/smile.gif
/ Dirt Scoop Customization #6
Mike, is the "dump lever" truly work like a lever??? ie. do you push or pull it forward or backwards, or do you, like the old tire rope, pull it up?
I push it backwards. With a heavy load I will lower the scoop first to take the pressure off the trip arm.
I found a steel rod laying around the barn and put it in the vise to create the proper bends. The handle is off a fence for a table saw I use infrequently.
/ Dirt Scoop Customization #8
Did your 7500 come with that back sheet metal part that holds the upper link or did you get that seperate? How much was it?
It was not standard. You can purchase one from your dealer for about $32. It is for a B2410.
Very handy to have when changing implements. Great temp storage for your toplink.
2009 IC Corporation School Bus, VIN # 4DRBUAAN39B694287 (A65563)
2009 IC...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
Allmand Light Tower (A65579)
Allmand Light...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
FRONTIER HYD BALE SQUEEZE (A64277)
FRONTIER HYD BALE...
