Digging holes with a Front End Loader
/ Digging holes with a Front End Loader #21
Scoops really aren't for digging as their main function. There more for moving loose materials usually that is piled. Don't see them as often anymore since FELs are common on small tractors.
/ Digging holes with a Front End Loader #22
Thanks for the compliment, Scott, and actually, Blake, that's probably the best $190 a guy could spend on a 2wd tractor, but not for digging.
/ Digging holes with a Front End Loader #23
Mosey, You will never regret getting a FEL for your tractor. What I would do is after you get the FEL spend the money that you would have to spend on renting a mini-excavator on a big dumpster. Then use the FEL to load the bricks/blocks into the dumpster. It probably would cost you less and you are not messing up your beautiful property.
/ Digging holes with a Front End Loader #24
<font color=blue>Mosey, You will never regret getting a FEL for your tractor. What I would do is after you get the FEL spend the money that you would have to spend on renting a mini-excavator on a big dumpster. Then use the FEL to load the bricks/blocks into the dumpster. It probably would cost you less and you are not messing up your beautiful property. </font color=blue>
Brilliant idea!/w3tcompact/icons/grin.gif
/ Digging holes with a Front End Loader #25
How big are the augers for your PHD?
If u had a 24" or so use it.
Drill lots of holes and put the rocks in them.
Seriously, have any neighbors that need
fill see if they would take them.
/ Digging holes with a Front End Loader #26
I dug a 4ft deep hole for a dry well using my JD 4200 FEL. Encountered 2 or 3 large rocks, but was able to dislodge them and get them in the bucket (partially by hand) to get rid of them. Using bucket in vertical down position and then curling up, you can dig quite a bit deeper than front wheels. This was a bucket finesse project, as opposed to charging at the dirt to load the bucket. I was about to dig the hole by hand, and thought I'd try the JD for the fun of it. Glad I did, and I was amazed what it can do. PS, I'm new to tractoring. Ken
Spencer - Thanks for the idea. It would be better to just get rid of them! I think the main thing that the FEL can do that a rear scoop can't is lift things up high, so I could use the FEL to load the stuff up and get rid of it. What do I look for in the yellow pages for one of those dumpters? I've seen them, but never used one.
/ Digging holes with a Front End Loader #28
About my post, when I mentioned what I did about the scoop, I didn't mean to sound like I was being disrespectful. Sorry, I was just being sarcastic. :)
Blake
/ Digging holes with a Front End Loader #29
<font color=blue>What do I look for in the yellow pages for one of those dumpters?</font color=blue>
Around here (Californy) it's the same company that picks up our trash and recycle every week. They have a selection of dumpster sizes and some restrictions on how much dirt/rocks/concrete you can put in one. Seems they want to be sure they can pick it up again when it's time to come and get it. /w3tcompact/icons/laugh.gif
/ Digging holes with a Front End Loader #30
Mosey, I think you will find most of them listed under 'Rubbish' in the yellow pages. Just look around your area and see who's dumpsters seem to be the most popular. They are probably the most popular because of price. Like Harv said, make sure you tell them what type of materials you will be putting in there.
/ Digging holes with a Front End Loader #32
Not sure your intended dimensions are feasible, much less safe (cave-ins, remember?) with a FEL. Anyhow, 3 or 4 feet deep, with twice the distance on the trench length is reasonable. I've a 5' wide FEL on a Kubota 3410, and last weekend cut 9 small trenches for tree planting (latest "tree hugger" advice is to surround the planted tree - mine were mostly in 15 gallon pots from a nursery - with at least a few feet of soft earth on all sides but the bottom - I used a mix of mulch and earth I'd dug up). Anyhow, I had no major problems, in fairly firm ground, with scooping out 5' X 5' areas for the each tree (yeah, I didn't need that width, but with a 5' FEL - no choice) that were about 2 feet deep. With some modest slope to 2 sides of a trench, and 4WD, should be no big deal to dig a deeper hole - in 1 area I made a short trench (15' by about 3' deep) to plant some 2 trees, and drove my tractor down into the trench, no problem (if you have time on your hands), but had to scoop out enough earth to accomodate the width of my back tires.
Good luck. You'll do fine - but forget putting your tractor into a deep, narrow trench - at the end of the day, it's a beer that's appropriate, not another tractor to pull your tractor (or you) out of a collapsed trench.
Would a backhoe work better - you bet, but - if all you have is a FEL and time - - - -
2019 MULTIQUIP TOWABLE GENERATOR (A63276)
2019 MULTIQUIP...
(INOP) 36 BLADE DISC HARROW (A64278)
(INOP) 36 BLADE...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
2009 Polaris Ranger 700 (A64127)
2009 Polaris...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
