Dig septic bed with front end loader
   / Dig septic bed with front end loader #1
wacnstac
Hello, I am faced with digging a rectangular septic bed with size of 14' x 40'. Inspector requires open bed as opposed to trenches. All I have is a Kubota 2650 with FEL. Not sure a backhoe (at least ones without a lot of size) would be of much help anyway with a bed.
I do have a box blade with scarifiers to loosen up the top soil and grass.
The soil is pure sand. Anyone tackle such a project with a FEL? I know I will need a ramp to get down the desired depth. I don't know how long the ramp will need to be. I'm really stressed about keeping this level with a FEL. I suppose I could use the box blade to help with that.
Getting the rocks and the backfill in around the pipes is another story!
There are so many videos on YouTube on doing this with trenches but I can't find any with an open bed design.
   / Dig septic bed with front end loader #2
The missing dimension (desired depth) is important. Since you're talking about a ramp, I'm assuming it is feet and not inches. You CAN do almost anything. It's a matter of how much time you can spend on it.
Back in the early 90's I put a volleyball court (sand) in for our older boys. I only had the Ford 1210 with a back blade and dirt scoop. It was a few inches deep at one end and almost a foot at the other end. The spoils were used to build up around it to reduce digging. It was a lot of work. they barely used it and 20 years later I dug it all out and used it for backfill when we buried a 1000 gallon propane tank.
   / Dig septic bed with front end loader #3
I imagine your inspector might not be happy with the results of using your front end loader for this. If you disturb the soil in excess he might make your replan. Your going to need a laser transit to do it.
   / Dig septic bed with front end loader #4
I might try digging sand with a rear mounted pond scoop but don't know if the 2650 can handle it on the rear 3pt. I see used pond scoops for sale for $175 or so pretty often in Middle Tennessee.
If rock is buried beneath the sand, could bend your loader.
I do have a laser transit. Inspector is only going to see the perforated pipe laterals in bed of gravel before backfilling. He won't see how it was dug. It is pure sand. Not like the bottom of the bed won't absorb water after I am done.
There is not rock. Only sand.
Depth would be around 24".
   / Dig septic bed with front end loader #8
Is this sugar sand or sand that will pack and carry the weight of tractor with a bucket full of sand? Will traction be a problem when trying to dig or move.
Sand is also heavy so may require some significant ballast on rear to offset load on the loader.
Might want to experiment with how this works before committing to final depth grade.
I wouldn't call it sugar sand. I would think if we keep it moist traction with 4WD should not be a problem. My rears are loaded and I can put an implement on the back for extra ballast.
My biggest concerns are how long the ramp will need to be, and how to at least get a half baked level grade for the bed. I do have a laser transit but am not sure how to make use of it with a FEL. I guess with depth stakes. At the end there will be some hand leveling for sure. Could also use box blade to pull dirt out and further help with leveling.
Then there is the issue of getting the gravel in for the base of the perforated pipe laterals. Honest not sure a backhoe would help.
Like I said, lots of videos showing this done with backhoe and trenches, but none with a septic bed.
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
1998 INTERNATIONAL 9400 (A58214)
1998 INTERNATIONAL...
Milwaukee Electric Tools Sign (A57454)
Milwaukee Electric...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
Milwaukee Box with Electrical Supplies (A57454)
Milwaukee Box with...
